308 cam pulley group buy | Page 3 | FerrariChat
Discussion in '308/328' started by derekw, Jan 28, 2017.
  1. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #51 derekw, May 5, 2017
    Just an update on the group buy. The pulleys are now ready to ship and should be with me in a week or so. I got a pre-shipment inspection done and the metallurgy, dimensions and belt fit were good but some had marks in the anodising so had to be re-done. They might send a sample set with round teeth (36 tooth 8M HTD) if they are ready in time. For those wanting the round teeth it would be good to know whether the preference is for adjustable hub or just lots of holes to adjust with.
  2. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    Derek, how are these coming along?
    Dan
  3. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    They are en route to me and I should have them next week. Depending on my schedule I should send them in 1-2 weeks. Don't send money until I have them and have had them tested.
  4. 250288
    250288 Rookie
    Mar 8, 2015
    6
    Hi Derek, any news?
  5. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Let's guess who the stealth 250288 is-- 2 posts in 2 years. Probably someone who is not happy about this effort to get affordable options to whatever they are selling?
    As all the people who ordered already know, I was not happy with the belt fit so am getting them remade. You will be very pleased to hear that I may use the bad L belt pulleys and fit them with GT2 teeth so there will be budget GT2 belt options :)
  6. 250288
    250288 Rookie
    Mar 8, 2015
    6
    Hi Derek,
    Actually, I'm the bloke who PM'd you for one of your spare sets! I've heard nothing.
  7. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    My apologies for questioning your motives-- I was having a rotten day (not fun opening box after box of unusable pulleys that cost a few grand :-(
    Strangely, there is no message in my PM box from you so please send it again with your real name and contact details so I can add you to the list. Also let me know whether you want original belt (trapezoidal "L") or GT2 belt pulleys. The latter will be more expensive since you will get the 2 lower pulleys as well and they won't be ready for a few months if I do have some made.
  8. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #58 derekw, Jul 26, 2017
    Hi all,
    The pulleys with the new (correct) toothed section are now ready and will be sent out at the end of the week to US and Australia. Europe-bound pulleys will post from the UK in early Sept. I have a couple of extra sets due to some people dropping out due to the delay. If you want some let me know. $370 (incl. post) to US, add $10 for Europe and $25 more for other countries.
  9. skipgt4
    skipgt4 Formula Junior
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    they look great.
  10. mwr4440
    57,858
    Bavaria, The 'Other' Germany
    Mark W.R.
    Derek,
    From the pic I can't see how the pin holding the cog to the cam goes in.
    Can you show us?
    Plus, I'll PM you.
  11. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Mark, you unscrew the 4 locking cap screws, take of the mounting flange, put in your pin, reassemble.
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,207
    Dumpster Fire #31
    SMG
    hmm...
    That's going to make setting the belts and timing fiddly. The camshafts have a series of holes at 28* while the pulley has them at 25*, the OEM belt tooth is spaced at 12*. In order to take advantage of the range of of degrees both pulley and camshaft have a series of holes. Normal installation is to set the cams and using the belt find the nearest hole between the pulley and cam that also takes up all the lash and slack in the belt. A single fixed pin will make that a bit harder to do and without the outer cog in place I'm not sure how the belt is placed before the pin.
    I'd suggest slotting the inner part for clearance to make the pin removable without having to disassemble the pulley, just a thought.
  13. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I'll be using mine in the next few days and had just planned to put the pulley onto the cam without the central bolt (crank at TDC and cam locked at its TDC lift), check and mark which cam hole would line up best with a tight belt, remove pulley and put in the pin, reassemble and make final adjustment with the adjustment of the hub and then lock it up with medium threadlock on the cap screws and Loctite 648 or similar retaining compound on the flange/hub interface as I will not be playing around with the timing.
    I'll let you know if I'm missing something but it seems straightforward to me- but it's 3am and I may well be forgetting something.
  14. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    I'm sort of partial to the pulley design in post #1. Any chance to obtain some of those? Others may also what the more OEM style to make a group buy......
  15. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #65 derekw, Jul 28, 2017
    I have a few sample sets like that but the teeth are a little high and need to be machined down .5mm and the tooth corners radiused. I can try to get them in to the machinist but he already did me a favour letting my batch jump the queue and my local anodizer closed Wednesday for a few weeks.
  16. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    #66 derekw, Jul 28, 2017
    The pulleys fit well and it was easy to set up as described above. The Cat cams have so many holes it was easy to find holes that were correct for the belt teeth and had the adjustable hubs fully retarded (i.e. cap screws against the right shoulder of the slots.) I will use thread lock on the screws and Loctite 648 on the flanges. If anyone wants more insurance they could drill/tap a hole for a locking screw.
  17. mwr4440
    57,858
    Mark W.R.
    Derek,
    So you have or have not indexed the cams per the shop manual?
    Or are you just going with the "assembly marks" on the cams and "calling it good?"
    I know I have one cam (EX 5-8) 6 crank degrees off or maybe even 7 degrees. :(
  18. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    My 1982 has the same cam off the mark. I measured it twice because the other 3 cams were within 1 or 2 degrees.
  19. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,189
    CT
    John Kreskovsky
    I have to ask, what is the motivation behind changing the pulleys?
  20. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    John, I am replacing the 37 year old plastic pulleys since it is common for their guide rings to break off.
    Mark, my new cat cams don't have any timing marks so I used the lift data for the cams to index them. I used a dial gauge on the bucket lifter and set each cam to the specified top dead centre lift. I then put on the belt and tensioner, put a timing wheel on the back of the crank and turned it over a few times checking both the TDC lift and the degrees of max lift.
  21. johnk...
    Jun 11, 2004
    11,189
    CT
    John Kreskovsky
    Thanks Derek. That doesn't apply to QVs, correct. QVs have metal pulleys?
  22. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I think they switched to steel pulleys during the QV production so some have plastic.
  23. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I have a couple of sets that are cosmetically not the best (scratches or anodising not even/marked.) $250 set. I also may have two non-adjustable sets available next week if I can get them anodized ($320/set)
  24. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,387
    Canada
    Newman
    Only 2V 308's came with plastic pulleys but not all did and the same applies to boxers. I've only seen one 78 BB512 that had plastic pulleys and it was pretty near virgin status when I worked on it. I replaced them with new OEM steel gears.
  25. DANCER308
    Oct 24, 2009
    935
    KY
    Dan
    Received mine, they look great. Can't wait till early winter to put them on.
