News
308 Cooling system questions
Discussion in '308/328' started by SoCal308GTSiQV, Jun 22, 2009.
  1. SoCal308GTSiQV
    SoCal308GTSiQV Formula Junior
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    Car: 1983 308 QV
    I need to replace my coolant.
    How many gallons of coolant does the system require?
    Where is the best place to drain the system completely?
  3. BigTex
    Rossa Subscribed Owner
    Dec 6, 2002
    74,280
    Houston, Texas
    Bubba
    If you disconnect the vertical aluminum riser piping at the front of the engine, most of it will hit the ground....
    That's Step #1 of changing the alternator....LOL!
    Maybe others have a better way.
  4. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    722
    Green Cove Spgs FL
    Harry Welch
    That's what i did ,but get a large pan.My 82 holds about 4 3/4 gallons.
  5. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,366
    NY
    Take a look in the OM and I think it will take about 19 qts. What i did for future reference and changes is go under the car and take off the aluminum belly panel . You will see the main water line and tee'ed off of it is the 5/8" heater line. I cut this and added at tee fitting . When you do it the 1st time just remove the hose from the fitting and have a 5 gallon bucket available. There is also a petcock on the block below the right hand header closest to the rear of the car. This will drain the rest of the block. Have fun
