308 Gearbox Drain Plug. | FerrariChat
Discussion in 'Technical Q&A' started by seschroeder, Mar 21, 2004.
  1. seschroeder
    seschroeder Formula Junior
    Apr 25, 2002
    251
    Alexandria, VA
    Steve Schroeder
    Might anyine confirm that the gearbox drain plug on a 82 308 (I suspect the year really doesn't matter) is a 12mm.
    Thanks in advance.
    Steve Schroeder
  2. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Yes it is a 12mm.
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,924
    The Cold North
    Tom
    Oil is 12mm,gear box is 10mm on my car
  4. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
  5. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    I just checked all of my 308s. 2 of them use 10mm and one the latest being an 85' QV use 12mm for everything from the gear box drain to fill in the rear.
    Yes oil is always 12mm on all of my 308s.
  6. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    My 308 (1977 GTB) is 12 mm on the engine oil and 10 mm on the gearbox.
  7. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    I changed my transmission fluid this weekend.
    I did it according to the procedure here:
    http://www.cameragear.com/ec/gearbox.htm
    1978 308.
    The 12mm drain plug closer to the front the car is the engine oil drain. The 10mm gearbox drain plug is the one closer to the rear of the car.
    The Gearbox DRAIN plug on my car is 10mm!
  8. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    Engine oil plug - 12mm
    Tranny oil pan plug - 10mm
    Tranny oil-level hole on the side of the gearbox, beside the diff. - 12mm
  9. miked
    miked Formula Junior
    Feb 7, 2001
    895
    Cincinnati, Ohio
    Of course one could go to Sears and spend (invest) $20 on a SET of metric hex bit sockets and have all the sizes that one might need. Your future ENZO might require a 17mm! ;)
  10. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Right. Been there, tried that. They have a set that goes up to 10mm, but that's it--no 12mm. I ended up using an allen key, which worked well, especially given the breaker bar I had to use to get that little extra torque :).
    --Mike
  11. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    You may need to take a trip up to Canada... I bought my 12mm (individual piece) from the Sears here.
  12. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I had the same problem. I couldn't find a 12 mm locally. I had to order it online. Paid more in shipping than I did for the socket!
    Birdman
  13. ClydeM
    ClydeM F1 World Champ
    11,825
    Wayne, NJ
    Clyde E. McMurdy
    My local sears (NJ) sold both sizes individually.
  14. Wasco
    Wasco Formula Junior
    Dec 9, 2003
    486
    Salem
    Randy
    I got my 12mm large allen wrench from Sears in Oregon! If they have it in Oregon they should carry it everywhere else!
  15. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Sears sells the 10mm and 12mm separately.
