News
308 GT/4 asking $105,000 - gold plated?
Discussion in 'Australia' started by pacoll, Mar 3, 2008.
  1. pacoll
    pacoll Karting
    Oct 4, 2007
    75
    Gold Coast, Qld
    Perry Collier
  3. Aircon
    Aircon Eight Time F1 World Champ
    Jun 23, 2003
    87,124
    Melbourne, Australia
    Peter
    bargain....you better snap it up.
    did you see the other one on drive.com.au ? i posted the link somewhere yesterday.
  4. laminator
    laminator Formula Junior
    Dec 27, 2007
    924
  5. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,605
    Mount Isa, Australia
    Pap
    Hmmmm..........righteo. ;);)
    FERRARI 308 GTB DRYSUMP LIGHTWEIGHT $220,000
    History: Drysump lightweight 1of 154 made, Red/Sabbia only an amazing 4700 miles, 1 owner.
    Stored many years and exhibited at the bridgenorth motor museum.
    They have removed the engine/gearbox, stripped down, checked components as a precaution, they have converted the engine valvesfor unleaded petrol. The chassis suspension and engine bay are beautifully prepared making this probably the finest low mileage glassfibre, lowest mile in the world. Would suite collector
    I wouldnt buy it now, because of that!!! :D:D
    Would have been better off leaving the engine/gearbox untouched. Just remove heads and replace valves, thats all they should have done with that. :):)
  6. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,605
    Pap
  8. Aircon
    Jun 23, 2003
    87,124
    Peter
  9. wrxmike
    wrxmike F1 Veteran
    Silver Subscribed Owner
    Mar 20, 2004
    5,744
    AU
    Michael
    Sounds ok, has all the sensible stuff done, would be a good "driver" and would likely provide years of trouble free motoring.
  10. wrxmike
    wrxmike F1 Veteran
    Mar 20, 2004
    5,744
    AU
    Michael
    PAP,
    Would have needed new seals / gaskets after sitting for 30 years, and once the heads were off ( and engine out) it's not that much more work. When it's sold, the price will set a new benchmark for RHD, dry sump fibreglass GTB's*.
    While 220k seems steep at first glance ,consider that a ratty 246 Dino will sell for around 200K , in which case a pristine, rare GTB seems a bargain at that price, so perhaps it's not as OTT as it seems.
    Also, i doubt you could buy a dry sump GTB and restore it to the same condition as this car for anywhere near 220k all up, and you would still end up with a resto, rather than an original car.
    For the same money you can buy a 360, a 355 or even a 550, but this car will appeal to a buyer that wants something unique. And which car is likely to retain its value better ?
    As someone else says: " *rarer than an F40" LOL.
    M
  11. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,605
    Pap
    You mis-understood me mate. :):)
    It probably is a good price and I am not questioning the rareity of the car. I would also much rather have this over a 355,360 ect....:):)
    But.........this car has only 4700 miles?? You already know the next owner of this car WOULD not drive it, as it is a collectors item, so why pull the engine apart, inpect still like new components/bearings/rings, then put it back together with new seals. Cam and crank seals can be replaced without engine dis-assembley anyways. All you have to worry about now is, if some knuckle head assembled the engine correctly. It will be more prone to leaks now, than it was before. It may even fly apart, who knows? You would like to think they did a good job. Nothing like a tight/factory sealed engine, if you know what I mean? :D:D
  13. wrxmike
    wrxmike F1 Veteran
    Mar 20, 2004
    5,744
    AU
    Michael
    Pap, I understand where you are coming from, but I suspect your view of "stripped down" is a bit more throrough than a car dealer/ broker would do, hence I don't think they went deep enough in to it to truly F*ck it.
    IMHO they would have done little more than take the bottom cover off the gearbow and looked at it - then claim "inspected" , same for the engine - when they took the heads off , they casually looked at the bore, hence "inspected".
    No way would they have stripped the drvietrain down to each component part, measured the tolerances, then crack tested all critical bits and only if ok, assembled it. If they claimed that, I would want to see evidence.
    I agree with you about the next owner - I can't imagine someone buying it to actually drive!
    While its nice to have a good car, its even nicer to have a car that you can drive.
    M
  14. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,605
    Pap
    If you read it again mate, thats what they said they did. :):)
    *"They have removed the engine/gearbox, stripped down, checked components as a precaution"*. :):)
    If they did it or not, proof would be nice of course. :):)
    Either way, they were better off leaving it alone, but thats just my opinion. :):)
    Its a nice car.......
  15. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,780
    Brett
    I gotta dry sump Heavy Weight" lol. If only it were aussie spec I would be sitting on a gold mine after restoration. lol :):)
  16. Aircon
    Jun 23, 2003
    87,124
    Peter
    no...it would still be worth nothing
  17. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,780
    Brett
    Doesn't matter, I'm not selling it. Was joking oon two comments recently made. 1, Aussie Spec, and 2. Fibreglass.
  18. Aircon
    Jun 23, 2003
    87,124
    Peter
    duh...ya don't say? :rolleyes:
  19. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,780
    Brett
    Do you think you could be positive just one night????
  20. wrxmike
    wrxmike F1 Veteran
    Mar 20, 2004
    5,744
    AU
    Michael
    I must have missed it , where does it say Aussie spec ?
    AFAIK that GTB is a recent UK import.
    M
  21. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,780
    Brett
    Mike this goes back to a recent thread. ( I was just winding PP up as one does. He thrives on it :))
    http://www.ferrarichat.com/forum/showthread.php?t=186499
    There was a lot of discussion regarding aussie delivered cars.
  22. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    3,983
    maurice T
    I could be wrong but I dont really think there is a big difference on the resale with imports to local cars when it comes to GT4/B/S
  23. Aircon
    Jun 23, 2003
    87,124
    Peter
    i think you are...but that's just my opinion.
  24. Aircon
    Jun 23, 2003
    87,124
    Peter
    probably not.
  25. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,780
    Brett
    Your apprentice is doing very well. I had to Google one of his words. Very impressive.
  26. wrxmike
    wrxmike F1 Veteran
    Mar 20, 2004
    5,744
    AU
    Michael
    Oops, I missed the subtlety of that....
    M
  27. Aircon
    Jun 23, 2003
    87,124
    Peter
    he's not my apprentice...he's his own man.
  28. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,780
    Brett
    Thats ok M, I've learnt in my short time here that things can change quickly. VERY quickly. :)
