308 gt4 Broken window frame | FerrariChat
Discussion in '308/328' started by Andrew Smith, Oct 2, 2019.
  1. Andrew Smith
    Andrew Smith Karting
    May 9, 2010
    81
    Southern Norway
    Someone broke my drivers door window frame. It's the only real join, the top back corner 90 degree corner where the frame is cut at an angle. Shown in the first picture. Anyone fixed one of these before? Also Im looking to replace the window channel, as it seems to be time. The usual suspects have it in stock, just wondering if anyone has found it available elsewhere in USA?
  2. absostone
    absostone F1 World Champ
    10,015
    I would check ebay, ive seen them for sale before
  3. absostone
    10,015
    post more pics, im not understanding where you say its broken. the back 90 deg corners have a small tapered hex screw with a conical nut. the triangular window has a L bracket with flat head screws under the window channel
  4. Andrew Smith
    May 9, 2010
    81
    Southern Norway
  5. absostone
    10,015
    that's what should be there. check your passenger side and you will see
  6. Andrew Smith
    May 9, 2010
    81
    Southern Norway
    Ok, thanks. Will go pull the channels out and see what I'm missing!
  7. absostone
    10,015
    Interesting I don’t see the hole in your first pic
  8. Andrew Smith
    May 9, 2010
    81
    Southern Norway
    I was just looking at that too.
  9. absostone
    10,015
    what about the passenger side
  10. Andrew Smith
    May 9, 2010
    81
    Southern Norway
    I don't have access to the car right now, its in a workshop. Will go check tomorrow and report back.
    absostone likes this.
  11. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    Also missing the hex screw. The window channels can get bad, and I mean really bad. This could make the window stick. So it is not only an electrical problem that makes them slow. Make sure your window slides easy in the channel when you put it together. Do not drop them! On my GT4 the channels were in terrible shape.
    /Peter
  12. Pero
    Pero Formula Junior
    825
    Sweden
    Peter R
    ... and you can use some dry lube, like PTFE, in the channels..
    /Peter
  13. Andrew Smith
    May 9, 2010
    81
    Southern Norway
    No screws in the corners of my windows either. My profiles are nowhere near that bad, windows work great for years thanks to Birdman... I am looking for that window profile though, if anyone has a good source, I can't believe its Ferrari specific?
  14. absostone
    10,015
    the top and side is 90 degrees , 45 degrees each mitered, how can it not have screws???????????
  15. Andrew Smith
    May 9, 2010
    81
    Southern Norway
    Thats exactly my question. There are no screws...
  16. BigTex
    79,368
    Houston, Texas
    Bubba
    I want to pop in and say by my 1977s the screw and conical nut (WTF???) are definitely there, as mine was lost when loose, had to make it out of a pine tree....
    But the earlier chrome GT4, if the machining is not there for the bolt at a 45 degree thru both parts, perhaps this was a wishful solder joint on the earlier frames??
    As people yank the whole door closed by the rail (on GTBs) I can definitely see a weld "giving up"....
  17. BigTex
    79,368
    Houston, Texas
    Bubba
    Dig into the Parts books as an inner clip of spring steel, with tangs to bite the mullions would work, but I zoomed in and see NO evidence of such an insert rusting away, to failure.
    It would have left a mark
  18. Andrew Smith
    May 9, 2010
    81
    Southern Norway
    Agreed, no such markings. There is a sign of some sort of "solder" or "weld" on the cut surfaces but its not easy to see what it is or how they got it in there. See the attached photo, there is some uneven deposit there. Can you solder aluminium?
  19. absostone
    10,015
    Screw them together anyway
    Andrew Smith likes this.
  20. BigTex
    79,368
    Houston, Texas
    Bubba
    Yours are chromed, our later ones are black anodized, so any kind of heated joinery would mar the finish.
    I guess that's a 1976 Italian version of JB Weld!
    Now, easy enough, to say "use the screw kit", but if anyone kind find the countersunk metric bolt, hex socket IIRC together with the matching nut that is also countersunk it's shaped like a cone, well I need one to replace the bolt and nut I ground up to fit in there!!
    :D :D :D
    I suppose I could take the other side apart for a picture, it's some weird stuff!!!
  21. absostone
    10,015
    Anodized sir. not to difficult to make a conical nut. Double nut on the hex bolt and grind away
  22. francisn
    francisn Formula 3
    Apr 18, 2004
    2,015
    Berks, UK
    francis newman
    Really Big Tex?? What year was that? Not sure black was ever original. In fact fairly sure it wasn't.
  23. BigTex
    79,368
    Houston, Texas
    Bubba
    Sorry I mean on MY car, not the GT4.
    But the mullion rails are the same extrusion, what I was trying to express.
    Yes, I used a hex nut and made it 'conical' with a grinder!
    And anodized it with a black Sharpie...….
