308 GTSi Euro Bumper Swap | FerrariChat
Discussion in 'Technical Q&A' started by flashman, Apr 1, 2004.
  1. flashman
    flashman Formula Junior
    483
    Star Valley, Arizona
    William Rappaport
    I am thinking of swapping the stock US bumpers on my 81 308GTSi for Euro bumpers. My question is: How difficult is this to do, and does it require any type of body or frame work to the existing structure of the car. Do you guy's think it is even worthwhile doing?
  2. BigTex
    79,218
    Houston, Texas
    Bubba
    I understand it's significant weight savings, but US bumpers are the best for smacking US cars IMO.
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I use my (US) 308 at the track and switched to Euro bumpers. The weight savings is significant. Looks better too IMO. Yes, if you do more than "nudge" something you might need to pay the piper, but you are careful in close quarters, right? As careful as those Italians, Brits and anyone else that drove cars on the other side of the pond. At any kind of speed it is not going to make a difference.
    I think the biggest issue is when you leave it in a prking lot and Great Uncle Frank or Grand Auntie Mary are picking up some groceries in the 74 Lincoln and...well you get the picture.
    It's a straight bolt on.
  4. flashman
    483
    William Rappaport
    The car is never left alone, so being "attacked" is not a problem. I take it, that it is just a straight across bolt up to the existing bumper anchor points?
  5. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    Flashman--it's also possible to push your US bumper in quite a bit via drilliing a small hole into each bumper shock and carfully easing the car into a strong , flat wall. The shocks compress and the bumper moves in closer to the clip. It still doesn't look as clean as a Euro, but it is an improvement in looks
  6. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,619
    Pittsburgh, PA
    Matt F
    Doc's response may seem strange, but he's right on.
    Do a search on the archived Ferrarichat pages, and you'll find pictures of this solution.
    When you weigh the costs and the benefits, I think that it's the way to go.
    If you really want to reduce weight, and impact resistance isn't that important to you, remove the bumper shocks, and re-mount your current bumpers with new brackets (that you'd have to fabricate yourself.)
    --Matt
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    12,917
    The twilight zone
    The Butcher
    :), you're right. I've got euro bumpers on mine, it saved about 35 lbs per bumper, but as bumpers they make really good turn signal brackets.
  8. flashman
    483
    William Rappaport
    I have access to a real smoking deal on a set of front and rear Euro bumpers for my car. I really am not concerned about being hit, and if by chance I do crash, well its a moot point anyway. I think the Euros look great and the fact that they will lighten the car is an added bonus. My big concern was the ease of installing them.
  9. f355spider
    f355spider F1 World Champ
    17,940
    I'm with Matt, ditch the bumper shocks, and fabricate or use the euro brackets and save even more weight.
  10. flashman
    483
    William Rappaport
    Dave,
    Will Euro brackets work on a US bumper?
    WilliamR
  11. sjmst
    sjmst F1 Veteran
    Jul 31, 2003
    9,853
    Long Island, NY
    Sam
    Why drill a hole?
  12. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Bumper replacement. Front: Remove 4 nuts attached to inside mount of bumpers. Disconnect turn signal light connector each side. Remove TS from bumper, mount to new bumper. Reconnect 4 nuts. Tighten.
    Rear. Remove 4 nuts, remove bumper. Place new bumper in position. Use washers to shim as needed for alignment. Tighten nuts.
    Time 30 minutes for both.
    No you don't need to remove the bumper shocks, although you can and will save more weight by doing so.
  13. flashman
    483
    William Rappaport
    pma1010: Thanks for the great advise, I will proceed with it.
    WilliamR.
  14. johnb@macarbon
    johnb@macarbon Formula Junior
    Feb 24, 2004
    808
    SF Bay Area
    John Borchelt
    The bumpers on my '83 were pushed in front and rear but they still were not compact enough. So I took off the rear and removed the inch and a half aluminum block from between the bumper and the shock. I then used a die to cut the threads down into the studs that are permanently inserted into the bumper (at least on mine). Off the top of my head I can't remember what the die size was though. Then I remounted the bumper. Biggest problem was trying to tighten the bolts. When you take out the spacer there is not much room in there. I'll post some pictures when I get a chance.
  15. Dr.T348
    Dr.T348 Formula 3
    Jan 8, 2004
    1,599
    Chicago NW Burbs
    Richard T.
    I have Euro bumpers front and rear. They bolt directly on to the existing brackets. See prfile. I had the front prof painted and clear coated.
    These are after market repro's designed to bolt on to US cars.
    Original Euro bumpers will no fit without changing the mounts/shock or fabricating new mounts.
