News
308 hood struts slip
Discussion in 'Technical Q&A' started by Whiskeyman, Feb 16, 2007.
  1. Whiskeyman
    Whiskeyman Rookie
    Jan 28, 2007
    31
    West Chester, OH.
    Mike Calvert
    I recently purchased a 1985 Ferrari 308 GTSi QV. It has only 7,105 miles on it and is in show room condition. The only minor problem I have is that the engine deck does not stay open. It appears the original struts need to be replaced. The dealer wants $97.00 each. Is there any other place I can go to for this component.
  3. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    Check our site sponsor, Ricambi. I believe he stocks them.
  4. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    I just replaced mine 10 minutes ago. As noted above, Site Sponsor Daniel at Ricambi America stocks OEM ones. Here is the link:
    http://www.ricambiamerica.com/product_info.php?products_id=221478
    Aftermarket ones are also available. See:
    http://www.partsamerica.com/ProductDetail.aspx?mfrcode=STR&mfrpartnumber=4760
    (Item - StrongArm #4760 Lift Support, Gas-Charged)
    There are other options - search on "lift supports" and/or "engine struts"
    This is something you can do yourself in about 1/2hr or less.
    --Mike
  5. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    You can have them rebuilt for about $32 apiece at Strutwise in Canada. Do a general search for that name . Frank irvine is the guy who does it and is a great guy. The only problem is slowness in sending anything back and forth across the border these days.
  6. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    #5 Mike328, Jun 21, 2009
    Quick follow-up. A couple of years ago, I replaced my OEM struts with these Strongarm ones I quoted above. Although they fit, they soon lost their "umph" and ability to hold up the engine lid. Some days would be OK, other days, no-go. Might have been related to temperature, but never really figured it out.
    I got tired of holding up the engine hood with my head, so took Doc's advice above and contacted Strutwise (Frank). These guys are professionals--very warm and personal service from Frank.
    I sent him my OEM struts which were in good shape, he turned them around in about a week, about $100. Figure about a week on either end for shipping to/from Canada.
    Just installed them (a 15 minute job), and they're perfect. At my request, Frank gave them a little extra pressure. Seems like a miracle that the hood raises by itself, but I should have done this a year ago.
    Just wanted to post this experience--I do not recommend the Strongarm ones I mentioned earlier, but very much recommend Frank's service at Strutwise (www.strutwise.com).
    --Mike
  8. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    An small side note. The proper orientation of the gas struts is with the larger diameter cylinder "up", that is, closest to the hood itself, and the smaller diameter pushrod "down," attached to the actual engine bay.
    This was first pointed out to me by Frank (from Strutwise, see above), and applies as a principle, not just these Ferrari struts.
    The struts in my car were indeed mounted upside down, with the larger diameter gas cylinder on the bottom. I checked the photos from when I first bought they car, and they were like this then.
    Keith Bluemel's Original Ferrari V8 also has pics of the correct orientation. I have seen pics of ebay cars with them upside down, however.
  9. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,267
    Cape Town, South Afr
    Jack Verschuur
    Confronted with the same problem 2 years ago, I went to a local wholesaler (South Africa) for these type of units and bought 2 new ones for around 20 Dollars each. The pressure in them was a little too low (the lid is quite heavy), so the upped the pressure a little. Been fine ever since.
  10. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    720
    Green Cove Spgs FL
    Harry Welch
    Same problem with mine Bought mine at T Rutlands last year.
  11. cmt6891
    cmt6891 Formula 3
    1,295
    Encino, Ca
    Carl T
    I had my original struts recharged by Frank at Sturwise as well. The Ferrari markings on mine are still very much in tact and was the primary reason to getting them rebuilt rather than aftermarket. $100 including shipping, back and forth, takes about 2 weeks.
    No longer available with the Ferrari logo as new from the usual sources.
