308 Horn Location | FerrariChat
308 Horn Location
Discussion in '308/328' started by Big Daddy, Mar 12, 2009.
  1. Big Daddy
    Big Daddy Karting
    Jan 3, 2009
    212
    Albuquerque, NM, USA
    RJ
    My horn has stopped working. I hear the relay clicking when I push the button, so I think the problem may be the horn itself.
    Can anyone give me instructions for accessing and removing the horn for testing? I have an '81 308 GTSi.
    Thanks.
  2. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    b4 you even take the horn out,there are three screw's on top,take those out and pry off the lid,squirt about 3-4 drops of 3 in 1 oil,put back the lid and see if that works for you,alot of times these horns need to be lubricated on a regular bases
  3. Papa Duck
    Papa Duck Formula Junior
    Jan 16, 2006
    351
    Las Vegas, NV
    Carl
    The unit is located in the right front near the headlight motor. Open the front boot and look between the right headlight and the spare tire well. You will see the the rounf top of the compressor with the three screws that were mentioned. No need to take anything apart.
  4. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,485
    Somewhere in NC
    Greg
    #4 Owens84QV, Mar 13, 2009
  5. Big Daddy
    Big Daddy Karting
    Jan 3, 2009
    212
    RJ
    I found the compressor in my car, but the location is a bit different than what is in the photo.
    I was wondering about the plastic tab on the top of the compressor that reads "oil". Should I be adding oil there instead of taking the cover off, or is this for adding oil as regular maintenance? And if so what kind of oil am I supposed to use? Thanks.
  6. Steve Magnusson
    25,149
    #6 Steve Magnusson, Mar 13, 2009
    Both -- some compressors have the oiling port (so add the oil there) and some don't (so you have to disassemble the cover to add the oil).
    A light machine oil is ideal (e.g., sewing machine oil, 3-in-1 oil), but almost any oil is better than nothing. (Assuming the +12V is reaching the electric motor) You might still need to disassemble and clean things up (if you are presently "frozen"), but try adding a few drops -- if it doesn't work immediately, it might after allowing a few minutes for the oil to wick around, but if still dead = disassemble.
    It really does help keep the compressor in better shape to "toot" the horn once in a while.
  7. Big Daddy
    Big Daddy Karting
    Jan 3, 2009
    212
    RJ
    Thanks everyone for your help.
    It turned out the compressor wasn't working because the fuse was bad. I replaced the fuse and the compressor worked but the horn did not sound (I oiled the compressor anyway). I removed the horn and it seems to have been clogged up with rust and mud. I tried to clean it out but it still didn't work.
    So, I installed a cheap plastic air horn I had lying around next to the compressor and connected it with a new air hose, and it is working great for now.
    I will see if I can repair the old horn. If it does not work I will decide if I want to keep my cheap plastic horn or replace the original, which T. Rutlands sells for about $110 delivered.
    In the meantime, thanks for all the advice. It is good to have a working horn again.
    Fort Worth 360 likes this.
  8. BigTex
    79,218
    Houston, Texas
    Bubba
    FIAMM horn kits are often available at local auto parts stores.
    Good you got it sorted......I found the headlight had pinched off the air lines....LOL!
  9. Neonzapper
    Neonzapper F1 Rookie
    Oct 19, 2008
    2,580
    MD/FL/Philippines
    Mykol
    So funny that we have to oil our horns! :)
  10. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Harbor Freight sells the horns for about $12.
  11. chris marsh
    chris marsh F1 Veteran
    5,568
    Detroit
    Chris Marsh
    This picture isn't helping me much. Does someone want to give me a clue to what I am looking at?
  12. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    First picture was taken fore of the front passenger tire in the area below the headlight. The area is almost too clean to be recognizable.
    In my car the compressor is on the other side of the bulkhead shown and the plastic tooters are in center ahead of the radiator and is accessible from above near the bonnet hinge.
