308 Oil pressure drop | FerrariChat
Discussion in 'Technical Q&A' started by 4returbo, Jun 3, 2006.
  1. 4returbo
    4returbo Karting
    Oct 14, 2003
    60
    Indiana
    Rick Oliver
    On start up my oil pressure seems fine and normal. As the car heats up over 200 oil temp the pressure drops. I think its about 60 @ 6000rpm and just past positive numbers at idle. Can this be adjusted with the oil pressure regulator or do I need a oil pump rebuild? Just so you know, the sending unit was replace about a year ago and it had an oil change last fall by Cauley Ferrari.
  2. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,416
    Grass Valley, CA
    David Driver
    Your car sounds like it's working properly. The spec is 10lb/1K(rpm) at operating temperature.
    Read this article by Aehaas: http://63.240.161.99/motoroil/
    You don't need to "fix" anything. Mine is the same.
  3. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    same
    Oil gets thinner as it heats up.
  4. f14dexter
    f14dexter Rookie
    May 4, 2005
    23
    Virginia Beach, VA
    Gus
    same here.
  5. DavidDriver
    May 9, 2006
    4,416
    Grass Valley, CA
    David Driver
    ...and there ya have it Rick!
    Good luck.
  6. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    58,451
    Australia
    mind you, if you put a mechanical gauge on it you will find much more reassuring numbers .
    I saw the same thing years ago on my GT4 and the sender unit got damaged so I got the dealer to put a new one in ($500 here in Oz) and it failed due to faulty diaphram - several units failed actually). Seemed there was a bad batch of these sender units made so I converted to a mechanical system and was always happy to see the unit dispaly 95psi cold and 75psi warm with 45 and 25 respectively at idle.
    You can't beat direct mechanical gauges for comfort, the eelctrical sender units never give me that secure feeling (worked on too many aircraft to trust crappy auto systems)
  7. DavidDriver
    May 9, 2006
    4,416
    Grass Valley, CA
    David Driver
    moretti,
    A&P?
  8. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Take your pick. AEHass' "rule" or, as I pointed out in his threads when he first espoused this theory (why isn't anyone listening?) what the manual says:
    "When the temperature is between 212F (sic) and the engine revs are approximately 6000 RPM the oil pressure should not be below 78 lb/sq in or orver 92,5 lb/sq in. If, with the engine running at the same speed and temperature, the pressure is less than 64 lb/sq in the engine revs should be properly reduced and the reason for the low oil pressure established."
    -1978 308 GTS owners manual p.60
