308 piston remove | FerrariChat
308 piston remove
Discussion in '308/328' started by osceola, Apr 29, 2009.
  1. osceola
    osceola Rookie
    Apr 22, 2009
    5
    due to a damaged sodium cooled valve I have a damaged piston,engine out ,heads off,not sure of this crankcase could someone give me the procedure? ThanksBUck
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,839
    Atlanta
    John!
    there are many engine rebuild threads if you search for them. a recent rebuild was performed for the very same reason you have. I say to search because it is a subject that has been beat down many times and it is a pretty information rich subject. Searching will yield loads of valuable information.
  3. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Heck of a post #1 and heck of a reply :):).
    Valve failure?
    Presumably because sodium filled?
    Request for crankcase rebuild procedure?
    Search for precisely what? :):)
    Not trying to make any particular point here. It's just that many here would love to have more details from the original poster. And searching will yield much if you are good at the keywords, etc. and persistent.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Complete your profile and give us some more information, perhaps we can help.
  5. osceola
    osceola Rookie
    Apr 22, 2009
    5
    I'm not sure of the lower end getting to the rod,what has to come off? Other than the piston engine looks good.I'm hoping to replace piston and restore valve train.Thanks, Buck
  6. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Buck, you have to get to the main cap for that particular piston - accessed through the bottom of the engine. Piston and rod will slide right out the top. If the piston was holed/melted because of a valve not seating you may also have some damage to the bore as well. It's not ideal but I know people often install a single 10 or 20 over piston because they don't want to spring for a new complete set of pistons and boring all cylinders (done best with removal of the liners). Doing the job right soon gets very expensive - $5-10K in parts alone.
    The sodium valves tend to fail not because they're sodium filled, rather, the clearances can close up over time to the point where the valve doesn't fully seat.
  7. rimoore
    rimoore Formula 3
    Nov 18, 2004
    1,353
    Island in Maine
    Richard Moore
    What years have sodium valves?
  8. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    I could be mistaken but I think its all 2 valve 308 series cars including GT4 and Mondial.
  9. osceola
    osceola Rookie
    Apr 22, 2009
    5
    I know I have to get to the rod cap.My question remains getting to the cap.What has to be removed to reach the rod cap on the lower end of engine?Do transmission components have to be removed?What I'm confused about is the makeup of the crankcase and the method of breakdown of the crankcase components to reach the rod cap.I assuming you can't reach the cap from the sump cover.The bore is fine ,no damage.Regards,Buck
  10. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    If im understanding right you have to pull the motor and seperate it from the gearbox in order to pull the damaged piston out
  11. Ferraripilot
    May 10, 2006
    17,839
    Atlanta
    John!
    I suppose one could remove the oil sump plate and get to perhaps a few of the rod nuts from the bottom, but certainly not all of them. The big question is, why would anyone want to do it this way?
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Sounds like the engine is out. Unbolt the gearbox and mount it on a stand.
    Where are you located?
  13. osceola
    osceola Rookie
    Apr 22, 2009
    5
    I live in central Virginia.Is it a big deal to remove the gear box from the block with engine out? Thanks,Buck
  14. Ferraripilot
    May 10, 2006
    17,839
    Atlanta
    John!
    #14 Ferraripilot, Apr 30, 2009
  15. osceola
    osceola Rookie
    Apr 22, 2009
    5
    Thanks,I get it.Regards,Buck
