308 Radiator Temp Sensor Question | FerrariChat
Discussion in '308/328' started by SoCal308GTSiQV, Mar 25, 2009.
  1. SoCal308GTSiQV
    SoCal308GTSiQV Formula Junior
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
    I have read online that the temp sensor that turns the fans on and off is similar to one used by VW and can be swapped in. Has anyone done this and if so do you know the VW sensor part number?
    My car is an 83 308QV
    Chris
  2. Modeler
    Modeler F1 Veteran
    May 19, 2008
    7,330
    State of confusion
    a.n.other
    Hi Chris
    Notice the "Sticky" threads at the top of this 308/328/Mondial forum section?
    One is the listing of all known interchangeable parts. Have a look through that or give the search function a try.
    Sorry, I don't know the number off hand.
  3. SoCal308GTSiQV
    Nov 3, 2008
    585
    Ojai, Ca.
    Chris
  4. dave80gtsi
    dave80gtsi Formula 3
    1,913
    Ohio
    Dave Meredith
    From that same sticky thread, and assuming that a NAPA store is close by to you:
    NAPA FS-193 Switch: On: 82 degrees C / Off: 68 degrees C
    This switch originally fitted to early 1980 Peugeot. Less than $25.00 USD. Perfect fit, completely interchangeable in every aspect.
    For comparison: OEM Veglia switch: On: 85 degrees C / Off: 76 degrees C
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,803
    Cerritos, CA.
    Fiat and Lancia also use the same sender.
