308 Rear View Mirror needed | FerrariChat
Discussion in '308/328' started by Aimhii, Jan 8, 2019.
  1. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Can anyone refer me to someone whom I can source a 308 Gtsi Rear view mirror - preferably in Canada ? I have about as much silly put as possible on it and it still moves....
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Outside or inside?
  3. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Inside
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Available on eBay.
  5. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    I Looked.....None are original Ferrari 308....
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I see one that is but has a small corner defect which you could switch parts with yours?
  7. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Its not just a corner defect....It has no way to switch day/night...so who knows what you will see when you put it on? ....I am not paying $330 plus $78 USD for a defective mirror...
    Anyone seeing this thread.....if you know of any mirrors for a 308, please contact me....
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,805
    Cerritos, CA.
    Whatever you please be careful removing the rearview mirror, this how I cracked my windshield. If you don’t have the original, pic below shows the original base that the 308 uses without the double sided adhesive, so when I got my new glass, I ordered the double sided adhesive which is the correct shape from Ricambi but the P/N shows under the 348 parts catalog. I installed the base with the double sided adhesive which is a better idea because It would be easier to remove the base off the glass in the future, not like the original which is more like permanent. This base is also the same use on the Lancia MonteCarlo/Scorpion and Porche 914 just FYI.
  9. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Thanks for the Info Mike, that must of been heartbreaking.....sorry to hear.
  10. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    You can see either one you wish by rotating the entire mirror up or down. (I never use day/night switches on mirrors anyway.)
  11. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    it doesn't work - stated that in ad - so if i dont know if it is stuck in day mode vs night mode....i dont think i am spending $500 on a broken mirror...
  12. miketuason
    Feb 24, 2006
    15,805
    Cerritos, CA.
    Oh man, I tell you as soon as I heard that “click” sound, I knew already and my heart just stop. Then it took me nearly nine months to find a windshield that fits after I had tried six windshield, so please be careful.
  13. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    I looked for many months for a good mirror and even bought a used one, took it apart to see how it was constructed and tried to find a fix for the day/night hinge tab-no luck. Most used mirrors have something wrong with them and they still are expensive.
    If you are looking for a used mirror be sure to check the following:
    The day/night tab is connected to the main mirror mounting by a thin piece of plastic, which acts like a hinge. If it breaks it will feel loose and won't stay locked in position...and obviously you won't have the night setting.
    The mirror has a thin, clear glass right behind the frame, then the actual mirror is behind. Both of these can be replaced, if necessary.
    The frame around the mirror can be removed. It is held on by four plastic tabs (two on the top and two on the bottom). The frame tabs fit into grooves in the main mirror body. If you use a thin knife blade, you can usually lift the frame to release the tabs on the top, then the frame comes off, but be careful because the outer glass can slip out. Work over a table with a thick towel on it.
    The main mirror is held in by some rubber inserts. If the mirror has been taken apart, some may be missing and you may have to duplicate them to prevent the mirror from vibrating.
    At the very least, if you buy a mirror, take it apart and clean the outer glass and main mirror. It make s a big difference.
    As stated earlier, use double stick tape, not glue to adhere it to the windshield.
  14. dflett
    dflett Formula 3
    1,632
    NY
    David
    It’s a Vitaloni mirror isn’t it?... it must have been used on another Italian car of the period. It might be worth search for other contemporary Fiats and Alfas? You just might find something identical without the Ferrari tax.
  15. miketuason
    Feb 24, 2006
    15,805
    Cerritos, CA.
    Read the last sentence on post #9
  16. dflett
    dflett Formula 3
    1,632
    NY
    David
    That is for the base. I thought the OP is asking about a replacement mirror. Are the mirrors on those cars also the same?
  17. miketuason
    Feb 24, 2006
    15,805
    Cerritos, CA.
    The one on the Lancia are not sure about the Porche 914
  18. jpl
    jpl Formula Junior
    Dec 4, 2003
    367
    Yulee Florida
    JP Lavigne
    They are or at least look the same as a mid 70’s 911 rear view mirror.
  19. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
  20. mwr4440
    57,922
    Bavaria, The 'Other' Germany
    Mark W.R.
    Fiat mirror. EXACT Replacement.
    Will set you back about $120.
    Look into the parts x-ref sticky above.
    Aimhii and miketuason like this.
  21. miketuason
    Feb 24, 2006
    15,805
    Cerritos, CA.
    You have pic of the Fiat mirror?
  22. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    Thanks Mark...That part number above....? IS that for the whole mirror or just the base?
  23. BigTex
    79,368
    Houston, Texas
    Bubba
    I tell you what....my shop managed to knock mine off, base and all.
    I find that after cleaning the glass off, I really don't miss it!!
    A have the larger rectangular Vitaloni Turbo door mirrors, to check the rear view.
    Let me make sure it has day/night function working.
    What would you pay for the correct 1977 OEM unit??
  24. Aimhii
    Aimhii Karting
    Feb 24, 2018
    104
    Oakville, Ontario
    Luba
    please email me at [email protected] - Hopefully can work something?
