308 Right front low beam headlight won't work. | FerrariChat
Discussion in 'Technical Q&A' started by Husker, Jan 8, 2004.
  1. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    I figured it was the bulb, so I replaced it. Wrong. Still no low beam. High beam is fine. And the left headlight, low beam and high beam are fine. Any suggestions on this one? Thanks!
  2. Diablo
    Diablo Formula Junior
    Well, I would say get a test light and see if you have 12 volts at the wires.
    If you don't, there could be a possibility of a wire that has an open circuit due to the up and down motion of the headlight unit.
    Good Luck
  3. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Check your fuse box. Make sure that it is not only the fuse but that power is going in and coming out of the box.
  4. markrolf
    markrolf Karting
    Nov 26, 2003
    116
    Kettering, UK
    Hi,
    I recently had the same problem. It turned out to be the connecter block just behind the headlight, where 3 wires go from the headlight into the car's wiring loom. Anyway, one of the connecters had come loose, simple as that!!
    Mark
  5. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    Same as Mark. My right headlight would come on then brownout. I wanted to see if it was the bulb so I switched bulbs and viola, both worked. Go figure.
