308 spark plug wrench | FerrariChat
Discussion in '308/328' started by johnvwatts, Feb 8, 2008.
  1. johnvwatts
    johnvwatts Formula Junior
    Jul 7, 2007
    522
    England
    John v watts
    Does any one know where I can get a spark plug wrench for my 76 glass 308 ?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,804
    Cerritos, CA.
    If you want the original that came with tool kit, try Ricambi
    or after market go to Sears, Snap-On, Mac, etch.
  3. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Does the '76 have the narrow tubes? With my '78 I had to take my Sears spark plug socket to the grinder for a few sessions before it would fit (and come out again :)).
  4. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Pick up one of those longer sockets with the swivel attached to it. I found they work great. Just be sure it has an O-ring in it to grab the plug, otherwise you'll pull the socket out and the plug stays behind, or you'll have a problem getting the plug back in (though I've found that a short length of hose works great for starting the plugs back in without cross-threading them).
  5. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Yes, good idea. I ended up buying a very short magnetic pick up that I used to extract the loosened spark plugs.
  6. Champboat/Champcar
    Champboat/Champcar Formula Junior
    Jan 29, 2007
    885
    Freeport NY
    Eric T
    You can also use the sparkplug extension to start the plugs, it works great just put a little tiny bit of antisieze on the threads, also its a good idea to use compressed air to shoot out the dirt or dust or condensation that forms there so it won't drop in the cylinders before plug removal, and the plug extension works great in removing the plug if it falls off the socket too .
  7. 308-newbie
    308-newbie Guest
    plug tool and a 3" extension fits perfect on my 77. Then I use an extender to pop the plugs out when they are loose.
  8. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
  9. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Thanks for the tips.
    I was afraid to tackle the front bank because i didn't know how i'd get the plugs out once they were unscrewed but the extender was the perfect tool to grab them.
    Took me less time to do the front bank than the rear thanks to this tip.
  10. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,441
    Canada
    Newman
    A snap-on socket fits without modification and the plugs remain in the socket so no fighting to get them out of the tubes.
    As for an original, try ebay too and chances are they are all the same for the 308. I have one and find it very handy, fits right and does the job perfectly.
