308 Turbo, sell or fix? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by 4returbo, Jul 30, 2004.
  1. 4returbo
    4returbo Karting
    Oct 14, 2003
    60
    Indiana
    Rick Oliver
    I am still wondering what to do next? I started the car up last night and on start up you wouldn't know anything was wrong. However, I heard a rattling sound coming from the engine that when away after a few minuets. Is this because sat for a long time? I'm really not sure where it's coming from or what it is? Could it be detonation? It sounds like metal clinking but then stops? Anyways the car was warming up no big problems then it started to smoke a white and blue smoke. Then the idle dropped and the black flicks of oil started spraying out the pipe. Very black the oil on the dip stick is clear. There was also a milky brown oil driping from the turbo junctions (I thinks from where it attaches to the cat box). Oh, can't forget that flow of coolant under the intake. Here's a theory. I have an air leak, head gasket leak, and metal flakes from something clinking in the engine or from past turbo problems. The air leak is the cause of high idle. The head gasket is causing the standing fluid under the intake and the smoking. The oil out the tail pipe? Perhaps my turbos are failing in part for lack of savenger pump?
    IDEAS?
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    If you compression numbers are right then there is just no way you're head gasket is bad. No way. If you doubt the numbers, re-do the test.
    It would be a good idea to do a leak-down test as well. since you can warm uo the engine, I would recommend doing the test on a warm engine, the numbers are more acurate. A leak-down tester is about $70 for summit racing, but I'm sure there are many other places to get one.
    The coolant leak needs to be fixed. That is your next step. Remove the intake and find the problem. You can not drive a car that is spraying out coolant, so fix it.
    After that, either put you old turbo back on and by happy or fix the new one and add a scavenging pump.
  3. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,194
    Kingsport, TN
    Lawrence A. Coppari
    Is the turbocharger water cooled? Does your car's coolant level drop or overflow?
    There are some coolant hoses under the intake that can leak. The ones on my 328 did several years ago.
    It sounds like you have leaking oil seals on your turbo(s). A happy foot before the oil is at operating temperature can cause this. Even in hot weather, my car takes about 10 miles to fully warm the oil. I do not think the oil system has a thermostat. But I am not sure of this. If I get into high revs on my 328 before warm, oil pressure climbs way up. I ruined an oil cooler doing this years ago before wising up.
    I have read from listers on another list that some brands of turbos are more susceptible to high oil pressure ruining turbo seals than other brands. Personally, I like turbos. I have a car with 148K. I purchased it with 90K and put a larger turbo in it and run 1.1 bar boost, nearly doubling the original power output of the engine. But the engine was designed for a turbo. I have over 50 track events on it.
  4. 4returbo
    4returbo Karting
    Oct 14, 2003
    60
    Indiana
    Rick Oliver
    No, the turbo is not water cooled. I haven't notice any major change in coolant level either. I like tubos too but now I just long to drive my car again.
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Very good point. 3x8s run much higher oil pressure than most other cars, especially when cold.
    I'd check with RayJay or the other turbo's mfg on the max pressure the oil seals can take & compare it to your car's pressure.
    Your symptoms do sound like turbos with blown seals. Not sure about the metal bits tho.
  6. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    The oil pressures seen at the turbo are no more than any other car I have worked on. I have had three of these converted cars in over the years, and the troubles have all related to lack of oil scavenge. The returns can block easily if the turbo is shut down when very hot, that's why you must allow a cool down period after driving, especially if ther is not a scavenge pump, all three I saw had pumps. One did have a detonation problem at max rpm as you shifted, and it spark knocked and puffed blue/black smoke. Hard to determine what is going on with yours, I would suspect at least the Turbo bearings, the noise is also worrisome on start up.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,870
    The twilight zone
    If the old turbo is a plain bearing type, then it would need decent oil pressure. There would be a decent flowing line to minimize pressure drop and the clearances in the bearing itself would meter the correct oil flow. The new turbos are all ball bearing if I'm not mistaken there is normally a flow restrictor such as a small (.060" orifice) somewhere in the feed line which also has the effect of dropping the pressure and setting the correct oil flow rate since a ball bearing is open and can not act as its own flow restrictor. That could easily be your problem.
  8. ulf308qv
    ulf308qv Karting
    Nov 1, 2003
    102
    Sweden
    Ulf M
    I agree with Brian. If there is no scavenge pump fitted, the oil return from the turbo has to enter the engine above the oil sump oil level. Looking at the photo, the turbo is mounted very low, hence it would need a scavenge pump.
    BR/Ulf
  9. wrecktech
    wrecktech Formula Junior
    Jun 4, 2004
    368
    Fort Wayne, Indiana
    Any update on your car? Do you think you are getting closer to finding the problem?
  10. Michael J
    Michael J Rookie
    Aug 26, 2004
    26
    Desert Hot Springs
    Michael S Janis
    If you still have this problem, I've come up against this twice. All though it was on other car's, it's probly the return line from your turbo to the block. I have had the same problem where it leaked oil, smoked and didn't have the performance that the other turbo cars had. If the oil doesn't cool, fresh oil coming in through the presure system the oil cooks and blocks the drain line. This cause's lot's of problems, oil leaks, oil into the manifold and if the turbow has a water cooled housing, can create problems there too. Hope you have already fixed the problem. Good Luck Mike
  11. 4returbo
    4returbo Karting
    Oct 14, 2003
    60
    Indiana
    Rick Oliver
    Thanks for the follow up. Thus far I have not made any major discoveries or progress. I have pressurized the cooling system to confirmed that I have a leak from under the intake manifold. Additionally, I found that I had two loose bolt on the plenum. After fixing that I started her up to see if my idle had improved. I believe it did but had to shut her down because of the amount of oil spray and smoke from the exhuast. My plan of attack is; ONE, complete another compression test of each cyl. TWO, perform a leak down test. THREE, access the results... if good... then I work on a the turbo set up focusing on a scavenger pump system. FOUR, fix coolant leak. Then take it from there.
    Thanks Mike
