308 turn signal adjustment | FerrariChat
Discussion in 'Technical Q&A' started by stacy, Jan 21, 2004.
  1. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    Can anyone describe the mechanism that turns the blinker off when you put the steering wheel back to the middle (77 308). Mine seems to be out of whack. Is there a cam on the steering column that can be adjusted?
  2. ferrarioldman
    ferrarioldman Formula 3
    Jun 19, 2002
    1,029
    Summerfield, NC
    Tom Jones
    This has to do with a plastic wheel in the column switch that trips a lever on the switch itself to release it so it can return to the neutral position. You will need to pull the steering wheel to see what I am talking about. The "wheel" also doubles as the horn ring.
  3. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    Can the "wheel" you are talking about be adjusted?
  4. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Stacy,
    The "wheel" can either 180 degrees out or in the correct position.
    MW
  5. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    Strange.
    Mine seems to be just a little out. My steering wheel is centered OK but it doesn't shut the blinker off when I come back from a right turn unless I over-correct a bit.
  6. Ferrari_tech
    Jul 28, 2003
    1,527
    Malcolm W
    Seems like you will have to pull the steering wheel off and have a look at the ring in the top of the switch which locates in the underside of the steering wheel boss.
    MW
  7. stacy
    stacy Karting
    Nov 2, 2003
    105
    halifax
    Will do.
