308 Water Pump Rebuild Question | FerrariChat
Discussion in 'Technical Q&A' started by christopher, Jan 15, 2004.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello Ferrari Folks,
    Need some advice:I 'm rebuilding a water pump on a 79 308GTB.
    I'l stuck on how the shaft comes out. Does it come out the nose front, or the rear. I've removed the small pin (whereas the pully slides over), and can get the thing to budge. Can you give me some direction?
    Thank you!
    Chris.
  2. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Remove lock from washer on acorn nut on impeller on rear of water pump.
    Remove acorn nut from impeller with 2 washers
    Remove impeller by gently prying up on edges and or gentle heating of impeller to expand metal against shaft
    Remove 19mm pulley nut by torqueing against the 10mm square left on shaft by impeller
    Remove pulley by tapping on pulley and or gentle heating of pulley.
    Remove woodruffkey with pliers
    Remove shaft by tapping with rubber mallet in the direction of pulley to impeller.
    Note that the shaft presses out the rear of the water pump housing. As shaft backs out the water pump seal will pop off. You may need a punch indexed on the shaft center dimple to drive the shaft beyond the inner bearing.
  3. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Just a little clarification:
    The shaft does remove from the rear of the waterpump?
    Its in very tight.
    Thanks Chris.
  4. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Correct, from the rear.
    If you have access to a hydraulic press,it's an easier job.
  5. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    My pumps seal went and got into the bearings. The shaft froze to the bearings. It is very difficult to get the shaft out when it is like this. Only a press will do. I tried a rubber mallet but that wouldn't work. A tip that I received was to put the pump in the oven on 250-300 for 10-15 mins. Then the bearings come out much easier. I used PB Blaster. I don't think it helped much though.
  6. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    Or, heat the front part of water pump housing and let gravity cause the front bearing to drop out. It can be persuaded by using a punch, to move aside the "shaft spacer" remaining on impeller shaft removal, and driving the front bearing out in the direction of impeller to pulley.
  7. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Thank you very much!!
    Chris.
  8. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Tod used a press and quite a bit of persuasion with a punch and mallet on mine. Took him about 5 minutes to pull it apart. However, as Skip ("Darolls") knows, he's done this a few times. You do want to be careful not to crack the housing. I don't think this is hard, but it is also not a job I'd do unless I'd seen it done elsewhere first. A small mistake will be an expensive fix.
