328 A/C condenser | FerrariChat
328 A/C condenser
Discussion in 'Technical Q&A' started by KurtK328, May 28, 2006.
  1. KurtK328
    KurtK328 Formula Junior
    Mar 6, 2001
    347
    Villeneuve-Loubet, France
    Kurt Kjelgaard
    Anybody know of any aftermarket/other carmake condenser which will fit the 328 without or with minor mounting modifications?
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    What's the problem with your old one?
    Usually minor leaks can be welded up.
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,431
    Canada
    Newman
    I need one for my 308 as well, any sources for the right ones?
  4. KurtK328
    Mar 6, 2001
    347
    Kurt Kjelgaard
    Verell,
    The skidplate under the front of the car has been rubbing the lower pipe coming out of the condenser and has rubbed the pipe thin - result: freon gone. I can have it repaired, but wondered if a substitute would be the way to go instead.
    This might be a heads up for other 3x8 owners - you will need to remove the front right wheel and the lower front inner fender to get good access for inspection.
    Kurt
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I don't know of an 328 alternate, but remember someone in the old Fchat days saying they successfully used a 'universal' one in their 308.
    Can't remember if it was from JC Whitney, or Summitt Racing tho.
  6. stevegtsi
    stevegtsi Formula Junior
    Feb 21, 2004
    316
    there are a lot of high capacity condensors available now which may offer better cooling. i would check old air products and vintage air. they have a lot of components available. good luck, steve
