328 AC hoses | Page 2 | FerrariChat
328 AC hoses
Discussion in '308/328' started by mike996, May 7, 2019.
  1. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    You can order partial kits. The stock coil works just fine.
  2. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,153
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Condensers are pretty generic things. Its best to buy as big of condenser that will fit (and with the fittings in a suitable place to connect the hoses).
    A big improvement with modern condensers is that they are parallel flow rather than serpentine flow. If you've converted to R134a, this will help get the vent temperature back down into the 30s F. … of course, it doesn't help with the bigger problem which is the (lack of) volume of air flow.
  3. 308 milano
    308 milano F1 Veteran
    5,351
    Montana
    Kim
    Mike if you do decide to replace your AC hoses please let us know if you were able to pull those through the original routing into the engine bay . Will be happy to be proven wrong but I just don’t see it with the fittings attached. Two sharp 90’s after exiting the rocker and pulled through a 2 inch opening behind the fuel tank.
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,912
    Mike 996
    I'll advise if/when I actually do anything re the hoses. We are in the UK now for 5 months and I won't be back to TX, where the 328 is located, until November.
    308 milano likes this.
  5. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    Maybe in the other direction? From the engine bay to the front compartment? So you wouldn't have to pull the 90° fittings through the tight openings.
    I'm curious as well.
    Best from Germany
    Martin
  6. 308 milano
    5,351
    Montana
    Kim
    I pulled mine from the engine bay forward also but without the fittings attached for condenser and dryer up front. Maybe framework is different in this area with later model 308/328 series but this is what I encountered with the 82 GTS. Project was really simple without the fittings attached upfront.
  7. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    160
    This is the way I did itl, too -- on my '77 308 GTB.
