328 Battery | FerrariChat
328 Battery
Discussion in 'Technical Q&A' started by Chiaro_Slag, Jan 7, 2004.
  1. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    My battery died - Going to get a new one - Quick question - When I took the old one out, it doesn't look like it is fastened down at all - Is this correct?
  2. Mule
    Mule F1 Rookie
    3,757
    Alaska
    Mule
    When I replaced mine it had a bracket that went from the front bottom and clamped the front top down. Sort of a metal doll rod with a hook at the bottom and a clamp and screw at the top.
  3. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    1 bolt in front of the battery, by the base. Look closely at how the bracket fits before removing it.
  4. Mule
    Mule F1 Rookie
    3,757
    Alaska
    Mule
    Dave Helms is right. Mine is the short bolt and clamp that clamps the lower front edge of the battery.
    My mistake on the doll rod (different vehicle).
  5. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    Can someone take a picture of theres? Looks like mine is missing. :(
  6. Ron328
    Ron328 F1 Rookie
    2,616
    Willamette Valley, Oregon
    Ron
    There should be a sort of a rectangular hold-down clamp in front of the battery tightened by a nut and bolt mechanism at the center. (I'll try to snap a photo of mine sometime tomorrow (I'm at work right now) if
    nobody posts yet.
    Ron
  7. MManzonelli
    MManzonelli Karting
    Nov 4, 2003
    82
    Columbia, IL
    Mark Manzonelli
    Just for information purposes the correct battery is Group Size 34
  8. Ron328
    Ron328 F1 Rookie
    2,616
    Ron
    #8 Ron328, Jan 8, 2004
  9. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    #9 Chiaro_Slag, Jan 8, 2004
    Thanks Ron328 -
    Is this the clamp you are referring to? I can't quite tell what is going on there - How is that keeping the battery in?
    Thanks so much!
  10. f355spider
    f355spider F1 World Champ
    17,962
    There is a "lip" on the bottom of the battery, that clamp is catching that, and retaining the battery.
  11. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    Thanks Dave - I have seen the lip (on both sides if I remember correctly, but don't have that retaining piece).
    *sigh*
  12. Ron328
    Ron328 F1 Rookie
    2,616
    Ron
    Exactly. There is a recent thread that posted a close-up photo of the
    clamp. It is available at Sodacom's (one of this site's sponsors).
    Good luck.
  13. tifosi
    tifosi F1 Veteran
    Sep 5, 2001
    5,382
    texas
    Tom D
    ferrari of uk has them if you can't find them here, BTW a battery jumping around is not a good thing as it reduces the life of it from vibration
  14. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    Thanks guys - I was hunting around for the part on Ferrari of UK, but was unable to find it. Thanks for the Sodocom's reference - I found it there - The problem is, it is just the bracket - That looks like it fits on a bolt and then the nut goes on top - I don't remember having the bolt - Is the bolt welded to the battery shelf, or does it fit through a hole down there? I'll have to take a look in there again to see if there is some kind of hole to put the bolt through.
