328 Coolant Dribble | FerrariChat
328 Coolant Dribble
Discussion in 'Technical Q&A' started by ScuderiaRossa, Mar 15, 2004.
  1. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
    My 328 just recently started to lose a small splash of coolant from the expansion tank drain hose. The car does not overheat while being driven, or even at idle. The leak occurs while the car is stopped and idling, just before I turn it off. Its going in this month for regular fluid service, so I'll have this checked out. Radiator fans? (I checked the fuses, they're fine.)
    Thanks.
  2. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    Mine did this last year, i bled the system via the small 10mm bolt on top of the vermostat, then it stopt. Worth trying.
  3. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    Chaa,
    I have the same problem. Could you please post a picture of the 10 mm bolt on the thermostat you are referring to?
    Ciao
    Eugenio
  4. zan
    zan Formula Junior
    Nov 15, 2002
    537
    Boston
    Mark M
    Bleed your radiator also
  5. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    Yes flyinboa i can but it will be tomorrow now. In the mean time i will try to tell you how to locate it. If you look at your engine and look to the right of it, just below the injection plenium again to the right of it you will see there is a half ball shaped alloy part about 1-2 inches across that a large warter hose joins from the right.....thats it, on it you will see the 10mm bolt on top of it. WARNING for F**ks sake dont unscrew it and drop the bloody thing, first time i did it,it took me 3 hours to find it.....bloody thing is right over the cambelts and other pullys. Hope this helps dude.
  6. tifosi69
    tifosi69 Formula 3
    Dec 23, 2003
    1,678
    Atlanta, Ga.
    Al-Al Cool J
    How often should that be done? Is it necessary between oil changes or does it depend on how hard you drive it?
  7. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,038
    E ' ' '/ F
    Ayagoa Kabooma
    Probably not the fans. You can check the operation of them by simply idling the car until the water temp reaches 195 F. They should both kick on at that time.
  8. ScuderiaRossa
    2,230
    Thanks guys. My mechanic said this happens sometimes. The coolant was changed last year, along with a water pump rebuild.
  9. f355spider
    f355spider F1 World Champ
    18,043
    Three things can cause this (typically):
    1) Overfilling the system; the coolant level should be 6cm from the filler neck.
    2) Bad expansion tank cap
    3) Overheating. It is usually the first two....
  10. Tod328gts
    Tod328gts Formula Junior
    Jul 23, 2003
    626
    River Forest, IL
    Tod Whitmore
    My 328 did the same thing after a water pump rebuild last year, i had the Major service done over the winter here and the mechanic said my Expansion cap was bad. They replaced it and i have no problems now...
  11. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    I know it sounds a stupid question... How warm must the coolant be before bleeding the air? Again, Please no laught...
    And thanks for the pictures to come.
    Ciao
    Eugenio
  12. f355spider
    18,043
    I would be very careful with bleeding air out of the thermostat. I have done it, and got very little air out, but more importantly it has no bleed hole, so as you unscrew it, it basically has to come out, and out comes scalding coolant. One must be very careful doing this hot. Might be safer to try right after a cold start.
    Then warm and bleed from the front.
  13. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    A mechanic warned my not to blled from the thermostat for reason's already mentioned. Bleed from the radiator with the front of the car slightly inclined. Also, a trick for a better seal for the expansion tank cap is to spread vasoline jell or di-electric grease onto the rubber gaskets within the cap.
  14. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    If your water level is OK, then in all probability it is the cap. Fcar caps are crap. I once bought a new one that was bad right out of the box. Take the cap to NAPA or similar and spend $5. Bleeding the radiator is important but unlikely the source of your leaking.
    Dave
  15. groovzilla
    groovzilla Karting
    Nov 28, 2003
    117
    seattle, wa.
    william
    when i returned home last night and parked the 308 in the garage after running about 20 min. i noticed a small puddle on the floor...it was dripping from the rear passengers side coolant overflow hose...my system is bled properly and filled to the correct level...car is running fine temperature wise and the fans are both operating properly...
    ...not sure why it would do this..
  16. f355spider
    18,043
    Double check the cold coolant level, should be 6cm from the filler neck in the expansion tank. If this is correct, just keep driving it and see if it reaches it's own equalibrium and stops spitting.
    If it keeps doing this, then get a new cap.
  17. groovzilla
    groovzilla Karting
    Nov 28, 2003
    117
    seattle, wa.
    william
    but we went away as it was my 45th b'day sunday the 14th...
    look forward to driving with you soon..
    william
  18. ScuderiaRossa
    2,230
    OK guys, just so I don't get the wrong cap, anyone know what the PSI rating is? My cap has the following text on it: Savara, the letters "C" and "G", and 09 bar.
  19. f355spider
    18,043
    Len,
    the .9 bar cap is the older style, the current one is rated at 1.1 bar. 1 bar equals 14.5 psi
  20. ScuderiaRossa
    2,230
    Thanks Dave. I almost bought a cap today that was rated at 13 PSI, but I thought I'd check with you guys first.
  21. Glassman
    Glassman F1 World Champ
    Similar problem and an easy cure. Bleed at the radiator which I do every time I drive the car, also warm the car up in the driveway with the cap off. It will really help to bleed out any air as soon as the coolant is moving with the
    thermostat open.
  22. f355spider
    18,043
    Holy cow, how often do you drive your car? Garage queen? :)
  23. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    BTW, older cars don't have the thermostat bleed screw. If you can't find it, that may be why!
  24. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    Does anyone know of a cross- reference number/ brand for a 1.1 bar expansion tank cap? Does Stant make a cap which would fit? I just brought my stock .9 cap to NAPA and , as soon as they heard Ferrari, no one knew anything.
  25. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    Also, how about a part # for the .9 bar cap? As my hoses are a little aged, I'm reluctant to pressurize them more than necessary.
