328 Engine is out! | Page 2 | FerrariChat
328 Engine is out!
Discussion in '308/328' started by Rod, Jan 8, 2020.
  1. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Does the bottom fork need undoing as a separate piece? Ie should I be holding the nut and turning the fork or just the nut? Its had a tap with the hammer so should now be separate from he body/hing.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    The bottom fork does not need to come off. You need to remove the four little bolts at the top-mid section of the mount, then the mount will drop through the hole. But you may have some rust issues.
    Rod likes this.
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,371
    Indeed, this is what the hangers look like when broken down. One of mine didn't make it out alive! I had to have that central bolt remade by a local engineer - think we used an M12 bolt to do it
    Rod likes this.
  4. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Easy when you know how! one is off the other is hanging on by one tiny nut which is the most difficult to remove! currently soaked in plus gas.... lets hope it comes free. I want to get them blasted and Now to try and split them down without breaking them!
  5. jallanblue
    jallanblue Rookie
    Jan 30, 2020
    1
    Juan Blue
    Yelcab, do you recall the contractor that you mentioned before. The one that sued for breach of contract and you won the case.
    Well as luck would have it I have crossed paths with him in NC and am currently in a court case. Any information that you could give me would be most helpful.
  6. dave80gtsi
    dave80gtsi Formula 3
    1,961
    Ohio
    Dave Meredith
    These hangers are still available, but the center bolt fork might need to be transferred over from your original unit.
    You want the VR-126-2 model. It is identical to the OEM unit, except the finish is black.
    https://www.vibrachoc.es/producto/vr-126/
  7. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
    Thanks.. great spot.... I will email them for a price... I guess they could easily be recoated if needed.
  8. Rod
    Rod Formula Junior
    Jan 18, 2004
    870
    South Derbyshire
    Rod
