328 engine is this a modification | FerrariChat
Discussion in 'Technical Q&A' started by dhs-9, Mar 10, 2004.
  1. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    #1 dhs-9, Mar 10, 2004
    Could anyone tell me if a spring connected to the engine vibration mount in the front of the engine which extends to a point to the left of the throttle linkage is normal. I've never seen this before. Any ides what this could be. see attachement
    Dave
  2. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    No it isn't stock.
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,967
    E ' ' '/ F
    Ayagoa Kabooma
    Not normal. Most likely it's a secondary return spring for the throttle.
  4. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    This is the way it should look like.
    Ciao
    Eugenio
  5. Tod328gts
    Tod328gts Formula Junior
    Jul 23, 2003
    626
    River Forest, IL
    Tod Whitmore
    I bet someone added this thinking the throttle was getting stuck and it was only the floor mat (Cruise control) just causing the stuck throttle.
    Before i knew it was the carpet, i was trying to think, maybe there needs to be an extra spring to pull the throttle back to idle????
  6. f355spider
    f355spider F1 World Champ
    18,041
    Agree with Tod, it was done either to correct the throttle not returning, or maybe it is a bit sticky. Either way, this is not a correct fix.
  7. Robert Johnson
    Robert Johnson Karting
    Dec 8, 2001
    57
    San Diego
    Robert Johnson
    Most racing bodies require 2 throttle return springs. What you have may have been required by the local autocross club or SCCA. Although, the stock throttel plate should have a return spring and the throttle position sensor should also be spring loaded. But it's up to the tech inspector on race day.
