328 headlight problem...new twist | FerrariChat
Discussion in 'Technical Q&A' started by btemplin, Jun 28, 2005.
  1. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    I know there have been posts regarding this topic in the past, but I've not seen any with the strange twist I'm going to describe.
    The right (passenger) side headlight stopped raising recently on my '86 328. The light is on, just won't come up. That's about normal, and I've read the posts concerning checking the fuses (which I haven't done yet). Now for the interesting part.
    While driving one night (headlights on), I really got on it excellerating onto the freeway. As I got to about 105mph, the right headlight came up. After backing off the throttle and slowing down, the light went back down once my speed dropped below ~100 again.
    It gets wierder. A couple of days ago, during the day (headlights off, only foglights on), I got up to ~105mph again. And the right headlight came up! Dropped down below 100, and the light went down.
    Anyone care to venture a guess at explaining this?
    Brian
  2. zebra308
    zebra308 Formula 3
    Jan 14, 2004
    1,339
    All Flimmits
    Ruffis Leekin
    Ferrari optional Airbrake system?
  3. f355spider
    f355spider F1 World Champ
    18,043
    Total guess...but I am thinking bad relay. Running hard and fast (higher rpm) gets the alternator spinning faster and perhaps increasing the voltage slightly, kicking in the recalcitrant relay....
    Just a guess, but I would try swapping relays, and see if the problems switches sides.
    But the part about it going up with only fogs on...now that is hard to explain.
  4. MJT328GTS
    MJT328GTS Formula Junior
    Mar 30, 2005
    374
    St. Louis
    MJT
    Perhaps the car was winking at oncoming traffic.
  5. Dr Tommy Cosgrove
    36,383
    Birmingham, AL
    Tommy
    Mine usually just like to go off and shut back down for a moment when I switch from high to low.
  6. wonkazoo
    wonkazoo Karting
    Aug 23, 2004
    190
    Woodside/RWC
    David
    Food for thought; ~105 MPH translates to 154 feet per second. (Or 46MPS if you are so inclined.) I would be truly astonished if standard 328 headlights were capable of illuminating something ~150' ahead of the car. (I have a 328 and I upgraded to Xenon. Believe me I know.) Let's assume for a moment that your headlights can illuminate your next 150'. Let's also assume that there is a bias-ply tire tread in the road in front of you. (Or a dead animal, or a dead fish, or a dead human, or a freakin' cheapass stereo speaker.) If you hit it it will do $$$ of damage. If you swerve in the 1/8 second you have to react you may well lose control of the car. Instinct will cause you to swerve, while seat time (If present) will cause you to hit it and deal with the cost later. Because you have so little time to react you are forced to choose between damaging your car, or trying to miss the obstacle. Most likely you will overcontrol, thus insuring your doom. Least likely- you will do countless thousands of damage that didn't need to be inflicted upon your Italian steed. In short you are travelling at a speed which will not allow you to avoid obstacles in the road unless you or your car are superhuman. Forget about your headlights, think instead about that which would drive you to push your car and your own mortality so close to the limit. If you want to push the envelope, do it in a fashion that allows you to survive until the next time. Should you miscalculate- which we all do, testosterone notwithstanding. (This from the individual that drives his 328 repeatedly in excess of 140MPH. In daylight of course!!) Again- food for thought- that's all!! (Because I want us all to be here for another 100 years or so.) As to the actual problem?? I have not a clue. (Although I think the higher V explanation is the best answer I have seen so far. Either that or an alien possession, but I think that's in another thread somewhere.
    Cheers,
    dce
  7. AaronB
    AaronB Karting
    Nov 6, 2003
    74
    Fallbrook, CA
    Aaron Marks
    I'm thinking maybe a little aerodynamics at work here..... maybe 105mph provides enough lift to open them, the blast of air keeps them open until you slip back down to 100 and then weight takes over and closes them again .....
    stranger things have been known to happen.
  8. f355spider
    18,043
    David,
    WAY too many assumptions in your diatribe. You are assuming driving at night, on a completely dark freeway, with no other ambiant light, whether from street lights, moonlight or other headlights....since you don't know the true conditions.
    Granted any fast driving at night is dangerous, but I am aware of clear, well illuminated stretches that would be very safe at night to drive quickly, especially since there would be little to no traffic.
  9. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    Isn't part of the 24hrs of Daytona run at night?
  10. Jdubbya
    Jdubbya The $10 Trillion Man
    43,087
    PNW
    Check to see if the bolts have come out of the bracket. I had my drivers side light fall in one night while driving home. Although it didnt fall straight into the hole I duppose it is possible if everything is lined up just right.
    When you turn the headlights on and the other light comes up, have someone stand by the passenger light and see if the motor is runing or not. Just make sure they keep thier fingers out of the way just in case!!
  11. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    #11 wolftalk, Jun 30, 2005
    I like the "blow it up" theory :)
    The lift motor drives a cam arm, and the arm connects to the lamp housing via an adjustable rod with plastic banjo-like fittings on each end.
    If the assembly is busted or fell off due to missing c-clip, you can lift the housing up with your fingers. However, if that's the problem, the front of the housing would not be level with the body.
    In any case, just open the hood and look at the side of the headlamp. You can see everything easily. Gratuitous picture attached.
    If that's not the problem, the only other thing wind could really effect is the wiring harness, so I'd pull the panel in the wheel well and see if the harness has gotten caught in the mechanism. Maybe the wires are getting cut into and shorting.
  12. Ferrari 328 Euro
    Ferrari 328 Euro Formula Junior
    Jul 19, 2004
    423
    Salem, MA
    Brandon
    It's the aliens messing with your head. Ask Tom Cruise!
  13. Dr Tommy Cosgrove
    36,383
    Birmingham, AL
    Tommy
    What if you are driving faster then the speed of light and you turn on the headlights? Would anything happen?
  14. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    I'd say Lord Lucas was playing games if it's one of their wonderful components.
    Ken
