328 Knock | FerrariChat
328 Knock
Discussion in 'Technical Q&A' started by Mule, May 2, 2004.
  1. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    I took the car out today, and as it was warming up in the driveway, there was a pretty loud knocking from the passenger side near where the intake hose is in the engine compartment. After a few miles I stopped for gas, and restarted it with no knock. When I took it home and let it cool in the driveway, then started it up, the knocking was back as I put it in the garage. Sort of three knocks, pause three seconds, three knocks, repeat.
    Car drove fine all day with no knocking (when warm), and this is the first time it has ever knocked in two years of ownership, even in colder weather.
  2. atheyg
    atheyg Guest
    Hard to say but I'd bet one of your belts are loose, Alt or A/C, I'd check them.
    As the car warms the belts tighten.
  3. speeder37
    speeder37 Karting
    Nov 18, 2003
    96
    Chicago
    Matt
    Check your water pump pulley. worn bearing act exactly the way you described. It will get worse fast.
  4. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    "Worse fast" enough time to take it to the dealer 60 miles away?
  5. Dave328
    Dave328 Formula 3
    Nov 24, 2002
    2,133
    Katy
    Dave
    If there is one thing I have learned working at a dealership, it's the value of a tow. The cost of a 60 mile tow pales in comparison with the cost of blown head gaskets or warped heads. I'm not trying to scare you since it's not even confirmed that it is a water pump, but, the piece of mind (at least for me) would be invaluable.
    Good Luck!
    Dave
  6. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    I talked to the dealer this morning and the point he made was that it goes away when warm as a direction in diagnosis. He suggested that the A/C compressor might be making the noise, or a belt. He said it might be the pulley, but the sound should continue when warm.
  7. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Started and drove it today - no noise. Odd. Any thoughts?
  8. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    If you cycle on the AC compressor does it change?
  9. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    I'll check today. A/C hasn't worked in years.
  10. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Still no noise. One time only sound?
  11. jbanzai
    jbanzai Formula 3
    Feb 1, 2002
    1,564
    Madrid, Spain
    Julio
    Was really cold were the car was when you started it? My car did a similar noise once when started on day at near 0 C.
    I was told by sevral other F-chat members that timming belts sometimes does that noise after a really cold night. The noise fades after a couple of minutes, and if weather is warm it will never apear again. BTW is a really scary sound!
    - Julio.
  12. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    It was very cold the week before, but even after a two hour drive, it came back after it cooled down and I was putting it in the garage. Hopefully, it doesn't come back.
  13. Jeffo24
    Jeffo24 Rookie
    May 2, 2004
    5
    Jacksonville,Florida
    Jeffrey A. Foshee
    The question I have is about getting into a Ferrari dealership and how to go about it. I am a 14year Ford tech..which I know is nothing compared to the car of my dreams, but I consider myself a top rank technician and not a mechanic/parts hanger and yes there is a difference. If anyone could possible help me with this it would be greatly appreciated.. My ultimate dream and goal is to work in F1 at some point in time.. you may email me at [email protected] or just reply to this message..and thanks again for taking the time to help.and i hope me posting this doesnt offend or make anyone upset..if so i am sorry in advance..
  14. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Jeff,
    Your post is fine, but it would get more exposure in the General Discussion or Technical section under its own thread. Not a lot of people are going to see it under this thread.
