328 motor mounts | FerrariChat
328 motor mounts
Discussion in 'Technical Q&A' started by GrigioGuy, Oct 9, 2005.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,072
    E ' ' '/ F
    Ayagoa Kabooma
    #1 GrigioGuy, Oct 9, 2005
    Greetings.
    The rear passenger motor mount on my 328 is sagging. I looked at the spare parts manual, and I think I only need part #19 in the diagrams below. It looks like that's the only part of the mount that could fail.
    Can anyone verify this is the part I need to order, or is there more to it?
  2. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    You are correct Tillman.
    That is all you need.
    Are you going to replace all of them or just the one?
  3. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    Also,
    The support that is not numbered on diagram could bent and that can be a fail point as well. But most likely it is #19
  4. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    Tillman,
    It's ok to say that you do not trust my 3x8 knowledge and that you are waiting for someone else to say the exact same thing I am saying.
    You will not hurt my feelings.
  5. JasonMiller
    JasonMiller F1 Rookie
    3,647
    Co Springs/ Texas
    Jason Miller
  6. GrigioGuy
    Nov 26, 2001
    33,072
    E ' ' '/ F
    Ayagoa Kabooma
    Thanks Jason!
  7. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    LOL!
    You guys suck :)
  8. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    We have them in stock - £57 (GBP) about $99 (USD) each plus shipping, and yes replace them all.
  9. GrigioGuy
    Nov 26, 2001
    33,072
    E ' ' '/ F
    Ayagoa Kabooma
    #9 GrigioGuy, Oct 16, 2005
    Grumble...
    The bolt on the bottom screws into the part/tube marked in red, which is supposed to be embedded in the rubber and not move. Mine's rotating. On the replacement mount that tube has two flat sides so that you can get a wrench on it, but the original is simply a round cylinder. I've already tried needlenose vise grips to try to hold it, but it simply rotates, and there's no room for other tools.
    Other than trying to grind the sides flat, does anyone have a suggestion?
  10. 4Webers
    4Webers Formula Junior
    Nov 12, 2003
    276
    Texas
    Darrell
    Tillman,
    It may be easier to cut off the head of the bolt that screws into it, then pull it up and out. Not sure about the clearance available to pull it up and out though.
