328 Not Started in 6 Years! | FerrariChat
Discussion in 'Technical Q&A' started by Bobdelaf, Jul 6, 2004.
  1. Bobdelaf
    Bobdelaf Rookie
    May 8, 2004
    2
    My father has a 1986 328 that hasn't been started in six years. He is in the Chicago area. Does anyone know what the best way is to get the car running again and how much it should cost?
  2. KurtK328
    KurtK328 Formula Junior
    Mar 6, 2001
    347
    Villeneuve-Loubet, France
    Kurt Kjelgaard
    Hi there and welcome,
    Search the archives - lots of info on what to do.
  3. Fiat Dino 206
    Fiat Dino 206 Karting
    Apr 19, 2004
    144
    Mississippi
    David
    With no history on the car to evaluate, it is impossible to tell what it might need to "get the car running again."
    When did your Father get the car?
    What is the mileage on the car?
    What is the service history of the car?
    Why was it not started for six years?
    The cost of starting the engine could be as little as $500.00 or as much as $8,000 according to who is doing what to get it started.
    The more the members know about the condition of the vehicle, the more likely the members might be able to answer your question.
    If the car was stationary for 6 years because of a mechanical problem this would be different than one that was stationary for 6 years due to the owners illness just after the vehicle had a 60K mile service.
    If you have any history on the car and the reason that it ended up not being used for 6 years, it may be that some of the members could help with the necessary information.
    Best wishes
  4. Tod328gts
    Tod328gts Formula Junior
    Jul 23, 2003
    626
    River Forest, IL
    Tod Whitmore
    Tell him to give the guys at Continental (Ferrari Dealer) a call, there number is 630-655-3535 and ask for Gary or Scott in Service. They should be able to tell your dad on what to do. But after 6 years, i would sugest a major service and replace those belts. Continental will pick his car up in an enclosed trailer too.... They are in Hinsdale, just west of Chicago on 294/Ogden. My 328 is there now....
  5. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    After six years not running I would suggest at the minimum :-
    Major service, including cam-belts.
    Replace all oils / fluids including brake fluid, coolant and a/c gas.
    Check tyres for "flat spots" - if the car has stood in the same position for six years then they are likely to be no good.
    Brake calipers could be siezed / discs rusty depending on what the storage conditions were like.
    Shockabsorbers don't like not being used as does the rest of the suspension, so a good checkover is required.
    Engine / gearbox oil seals dry out so a detailed examination when carrying out the service is a good idea.
  6. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    All fluids need to be changes (oil, gear oil, etc). Change T-belts, tensioner bearings, cam seals.
    Plus the clutch maybe stuck too. That happens a lot with cars that sit. You calipers may need to be rebuilt. I am sure the radiator is now plugged better pull it out too. All coolant hoses and thermostat. Just don't start it until everything you read here has been done.
  7. flyingboa
    flyingboa Formula 3
    Nov 27, 2003
    1,564
    Italy
    Eugenio Dalla Rosa
    Sorry, why to repost this as it is already in the Classic Section?
    http://ferrarichat.com/forum/showthread.php?t=23036
    Once should be enough...
    Ciao
    Eugenio
    P.S. Add to my previous abswer belt replacement, I forgot...
  8. spike308
    spike308 F1 Rookie
    Nov 8, 2003
    4,709
    Austin TX!
    Mike Z
    6 years??? what a shame....
    Tod... kind of suprised of your recommendation, given your A/C issues!
    I heard a story about a guys Dino in the Chicago area that had not been started in 6-7 years. Upon starting it... disaster struck, VERY expensive. Flat bed her to LFSC, Continental, or one of several independent shops in the city. A small insurance policy!
  9. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    I thought I had seen this before but couldn't find it
  10. Farmers Agent
    Farmers Agent Karting
    May 24, 2004
    153
    Welcome. Call Giovanni D'Aola at Autosprint in Chicago. He is a known Ferrari shop. The shop is 5257 W. Addison St. Ph# 773-685-0930. Tell him Dan Giacalone told you to call. He takes care of my 308.
