328 Oil running hot with gauge going up and down....help!! | FerrariChat
Discussion in '308/328' started by Gilgamesh76, Mar 2, 2024.
  1. Gilgamesh76
    Gilgamesh76 Rookie
    Mar 2, 2024
    10
    New 328 owner here. Put about 200 miles on last fall (worked flawlessly) and took it out today for a winter ride (no snow and warm). Noticed issues about 10 minutes into the ride. First, there was a light, almost clear, non-smelling smoke coming from the engine. It was hard to located exactly where, but towards the back by the firewall. It didn't appear to be blue or have that oil like smell. The oil gauge kept going from center (normal) up to the max level, then drop back down to center again; cycling every minute or so. With the engine off, it was making a slight hissing sound from the engine bay. Water temp was perfect and oil pressure was perfect as well.
    Any ideas or thoughts what could be going on? Appreciate it!
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Check your fluid levels. Also the dipstick method can vary from what I’ve seen posted….. FWIW when I change my oil I check the dipstick then what is actually in the drain bucket and filter. Yes can be different…. Just saying….
  3. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,277
    Illinois
    A little smoke might be ok because the cam seals weep a little. Mine were upgraded to silicon seals but still weep a little. No drips just a little weeping. So, on a nice drive where the engine gets good and hot, there is a bit of smoke. Not nearly as much as when the seals leaked more with rubber O-rings.
  4. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    The question of oil temp mid to max fluxing is concerning. I’ve never had max unless it’s run very hard…. Just saying….
  5. Steve Magnusson
    26,725
    Don't like your smoke-smelling symptoms (so that may need other attention), but the oil temp gauge swinging so much in such a short time, and in both directions, feels more electrical. (not easy for a big volume of oil to heat up that quickly, and, if it really did, it wouldn't cool off quickly). First thing I'd do is inspect the wiring going to the oil temp thermister -- chaffing/shorting to a metal ground can cause such a gauge movement (as grounding the wire = sends gauge to maximum).
    mike996, waymar, Saabguy and 2 others like this.
  6. moysiuan
    moysiuan F1 Rookie
    4,176
    Canada
    Oil burning off from a leak would not be non smelling, gear oil even more so. Maybe some coolant weeping from one of the hoses, or perhaps the clutch slave/hose against that firewall area is leaking some brake fluid. Not sure what cooking brake fluid smells like.
  7. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    388
    Herts, UK
    Richard
    Not sure 328's ever had a hydraulic clutch?
  8. Freddie328
    Jul 29, 2013
    388
    Herts, UK
    Richard
    Oil or water from a leak will usually find its way onto your garage floor, especially if you put the car away warm after a run.
    This should give you a clue!
  9. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,615
    France
    Bertrand
    Check the coolant level ( of course when it's cold ;) ) 10 minutes is short run and if all others thing is ok ...
    What about service history ? Any pictures ?
  10. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,082
    FRANCE
    Absolutely agree with this, even if my knowledge of automobile electrical matters is infinitesimally less than Steve's. But some good common sense here.
    Should you be stuck in city traffic with the car, and the oil temperature goes up to about 100° centigrades, you need about 10 miles of normal, un-impaired driving and free flowing air at say 55 mph (our equivalent would be 90km/h) for the oil needle to go slowly back to "normal" temp (= 75° centigrades).
    I do experience this very often; last time was on this very Tuesday.
    The temperature of 8 litres of engine oil cannot jump from 75° to 100°, or back from 100° to 75° in a matter of seconds.
    That must be some electrical connection to the temp gauge.
    Rgds
    mike996, Freddie328 and waymar like this.
  11. nerofer
    Mar 26, 2011
    12,082
    FRANCE
    No, it does not; the "Mondial" has one, but on the 328 the clutch is cable-actuated.
    By The Way, if my memory serves me well, suggesting that the 328 has an hydraulic clutch is one of the few errors in Keith Bluemel's book.
    Rgds
    moysiuan likes this.
  12. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,190
    Kingsport, TN
    Lawrence A. Coppari
    Does it smell like coolant? There are rubber hoses/connections in the valley between the heads. There also is a little thin-walled small coolant nipple that will eventually corrode away. It is attached to the small hose that goes to the coolant reservoir. The hissing you mentioned prompts my comment. You may have two issues, one definitely being electrical as previously mentioned. The other might be a coolant leak.
  13. Gilgamesh76
    Gilgamesh76 Rookie
    Mar 2, 2024
    10
    Thanks everyone for the suggestions! To address some of the leads provided...
    1) No coolant smell
    2) No leaks besides a tiny amount of oil (normal leakage); oil levels normal
    3) All fluid is normal
    Couple more questions/thoughts:
    1) Has synthetic oil; does that smell the same as normal oil with the blue haze? Maybe that is why I can't recognize the smell
    2) I'll check the wiring to the oil thermistor. Is there a why to troubleshoot the thermistor or is it best to just replace it?
    3) Could the oil cooler (radiator) be a failure point? Anyway to test that? It doesn't look like it has a thermostat like the water coolant system, correct?
    Really appreciate all the leads! I'll try and post some pictures/videos of the issue when I can.
  14. Steve Magnusson
    26,725
    If you do a search on the "107576" part number of the oil temp thermister, you'll get some prior threads -- like this:
    https://www.ferrarichat.com/forum/threads/oil-temp-sensor.587540
    I can't recall if the exact resistance vs temperature behavior for 107576 has been posted, but I would be surprised if it was radically different than the water temp thermister 104628 (and I know the resistance vs temp for that one has been posted).
    Gilgamesh76 likes this.
  15. Gilgamesh76
    Gilgamesh76 Rookie
    Mar 2, 2024
    10
    Hi Steve -
    Thanks again for guiding me through this troubleshooting. I have some updates...
    1) The wire and cap at the sender (thermistor) looked good...no damage
    2) I pulled the wire off the sender...no corrosion
    3) I turned on the ignition and tested the wire to the sender; it measured 7.4 volts DC
    4) I tested the resistance of the sender (cold) and it measured 4.6 Ohms with the meter set to 20K Ohms
    Not sure what to do next in troubleshooting the up and down spiking of the gauge. I really don't want to take the dash apart if possible. Questions...
    1) Should I warm up the engine and retest the sender to see if the resistance has dropped?
    2) Is there a way to test the gauge from the sender wire? If so, not sure the tool needed to apply different resistance.
    Happy to take any other ideas. I think the smoke might be a separate issue. I ordered an engine camera scope for my phone so I can probe around for the source.
    Really appreciate all your help! I'm a weekend warrior, so a lot of this is brand new to me.
    Thanks!
    Ryan
  16. Steve Magnusson
    26,725
    That (4.6 Ohms) seems a crazy low resistance, but if you mean that it was 4.6K Ohms = that's a high resistance for these thermisters. Usually the resistance of these thermisters are in the hundred to hundreds of Ohms ballpark. Please clarify.
    Certainly wouldn't hurt to make a resistance measurement of the sender both when cold and with warm engine to compare the values.
    One simple test to do here is:
    1. disconnect the wire from the sender with the disconnected wire not touching anything = the gauge should read minimum when the key is "on", then
    2. touch the disconnected wire to the engine block (with key "on") = the gauge should go to maximum.
    Gilgamesh76 and waymar like this.
  17. Gilgamesh76
    Gilgamesh76 Rookie
    Mar 2, 2024
    10
    I'll definitely retest the ohms. I tried testing the guage and it jumped to max, but was the water coolant temp gauge, not the oil temp guage. The sender I thought was the oil one was by the clutch cable. Is this the right one? It has one wire running to it and the sender looks to be attached to the bottom of the engine..oil pan I think. Image Unavailable, Please Login
    Sergio Tavares likes this.
  18. Steve Magnusson
    26,725
    Yes, that the engine oil temp sensor in the forward-facing side of the wet sump near the bottom -- item 34 here:
    https://www.ferrariparts.co.uk/diagram/ferrari/328-gtb-gts-(1985)/020-lubrication-system
  19. Gilgamesh76
    Gilgamesh76 Rookie
    Mar 2, 2024
    10
    Thanks...so if that is the right sender, why in testing it does the water coolant temperature gauge move and not the oil temp gauge? Do they share a wiring path or something? Sorry...just really confused on why the oil gauge didn't do anything yet the other gauge did.
  20. Steve Magnusson
    26,725
    #20 Steve Magnusson, Mar 6, 2024
    Well, that's pretty bizarro! The water temp thermister is item 35 here:
    https://www.ferrariparts.co.uk/diagram/ferrari/328-gtb-gts-(1985)/022-water-pump-and-piping
    You could try the same test on that wire and see what happens. I don't think they "share" anything. Maybe the two gauges are close enough to each other that someone had the dash apart and got the wires swapped -- just a thought. Or maybe they swapped the gauge positions, yet kept the same sensor wire attached -- have you confirmed that your water temp gauge and oil temp gauge are in the stock locations specified in your 328 OM?
  21. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,282
    Sergio Tavares
    Please plier tighten the female connector lightly so the connection made is firm not loose
  22. Gilgamesh76
    Gilgamesh76 Rookie
    Mar 2, 2024
    10
    Hi Steve -
    So...quite embarrassed to admit that I was looking at the wrong gauge. :( All this time, it has been the water temperature gauge that has been going up and down. I made the wrong assumption that the oil temperature gauge was next to the oil pressure gauge. Very sorry about that...rookie mistake! I think this explains some of the smoke now...must have been the coolant heat.
    With the symptoms shared earlier, I'm assuming it is a stick thermostat? If you agree, can that be replaced without draining all the coolant?
    Sorry for my error earlier! Appreciate everything!
  23. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    They dont, they are cable operated, I replaced mine a while back.
    G
  24. Steve Magnusson
    26,725
    I wouldn't guess "thermostat" with your report of the indicated water temperature going up and down so quickly -- so would still more suspect the wiring going to the water thermister or the water thermister itself (but doing the "ground the wire" and "not ground the wire" tests on the wire going to the water thermister could give you some confidence it is not the gauge if the gauge correctly, and always, moves from min to max for each test). I know people have posted what the resistance vs temp for the 104628 water thermister should be (it's used on many F models). I'd add that Lawrence had a good point that you may just have some sort of coolant leak from a old/bad hose or a corroded fitting letting out some steam/liquid -- especially if you are now using a 328 that was a bit unused/neglected for a while.
  25. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,868
    Mike 996
    It could. of course be an electrical issue with the sensor/gauge. Low coolant level can also do that; I hope it is one of those two. But my first reaction upon seeing your later post that it was water temp, not oil temp that was showing the variation was: possible blown head gasket.
    A blown head gasket can exhibit the water temp variations you are describing as well as the hissing which indicates pressure that is escaping from the cooling system after the engine has shut down. The smoke you mentioned (possibly coolant in the exhaust) is also be a blown HG symptom.
    Check the coolant level before going out for a run, then check it after the run when the engine has cooled. Along with the symptoms you described, If the coolant level drops from when the engine is cool before a run to low when the engine is cool after a run, I'd go from saying, "a blown head gasket is a possibility" to saying "it has a blown head gasket." :eek:
