328 Performance Modification Recommendations | Page 5 | FerrariChat
Discussion in '308/328' started by elms, Jun 7, 2021.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,923
    Mike 996
    Oh, OK, didn't know that either! I've been here since '08 and I'm learning a lot here in the past few days! :)
  2. Dr Tommy Cosgrove
    Dr Tommy Cosgrove Three Time F1 World Champ Owner Rossa Subscribed
    May 4, 2001
    36,637
    Birmingham, AL
    Tommy
    What are the ballpark numbers these days to simply rebuild the QV engine up in the 3.2 - 3.5 area with a nice bump in compression?
    ginoBBi512 likes this.
  3. ginoBBi512
    ginoBBi512 F1 Rookie BANNED
    Oct 9, 2016
    3,535
    SO CAL
    GINO RUGGIERO
    If I ever decide to take my 328 up to 3.5 Liters, will I need to change the ignition system ? , I really do not want to change the way things look outside the motor. My car is an 89 , the best run of the 3x8s, I have the Tubi / Test Pipe & K n N.The motor feels like 200 k miles will not be a problem. I wont be around to see 200k. One never really knows when they will need a motor rebuild / refresh .
    Thank you
  4. Rifledriver
    37,313
    Mine looks stock.
  5. Rifledriver
    37,313
    They are done a lot of ways. To do it what is in my opinion the correct way is expensive. I retained the aluminum cylinders, had them bored and replated. Its expensive. I changed everything that goes up and down because those are the parts that break. Only the big castings and parts that go round and round were saved. I had someone ask once and I told him the truth. It would be less expensive to buy a faster car. It is pretty unbreakable. 360 cranks can be used and have some advantages. I reused mine and had it stroked and renitrided. The counter weights needed modification to get out of the pistons way. Honda racing bearings in a non standard size so the rods were made to fit.
    Nice used Corvette is probably less money.
