328 RADIO STATIC | FerrariChat
328 RADIO STATIC
Discussion in 'Technical Q&A' started by Ivan BeRossy, Mar 3, 2004.
  1. Ivan BeRossy
    Ivan BeRossy Rookie
    Feb 18, 2004
    21
    ANYONE KNOW HOW TO GET THE STATIC FEEDBACK ON MY RADIO FROM THE ENGINE TO GO AWAY, IS IT THE 100W AMP MOUNTED IN THE REAR TRUNK?
  2. f355spider
    f355spider F1 World Champ
    18,038
    Could be any number of sources. Is this a recent event? Or has it always done this? On my 308, this was cured by switching to "resistor" type spark plugs. On my 328, the fix was to replace the motorized antenna with a new one.
  3. Ivan BeRossy
    Ivan BeRossy Rookie
    Feb 18, 2004
    21
    I've only had the car 6 months , did new wires and plugs etc. Comes thru the radio and the CD
  4. Enzo
    Enzo F1 Rookie
    Feb 14, 2002
    4,089
    MinneSOta
    Pat Pasqualini
    Try changing where the amp is grouded at. You can also try and ground the radio somewhere else also. But do 1 at a time so you know what cleared it up.
  5. Tod328gts
    Tod328gts Formula Junior
    Jul 23, 2003
    626
    River Forest, IL
    Tod Whitmore
    As already said, check the grounds of the Amp and Radio, you may have lost one. You may also have to add a filter CAP/Inductor to the power input of the Amp and radio to illiminate the noise...
    The Amp may have gone bad also......
