328 right lights not working ..?? | FerrariChat
Discussion in '308/328' started by F328GTS/GTB, Jul 19, 2009.
  1. F328GTS/GTB
    F328GTS/GTB Formula Junior
    May 3, 2005
    517
    France
    Denis
    #1 F328GTS/GTB, Jul 19, 2009
    Hi all,
    My 328 front right lights do not work since 1 week. All the rest of electrical items are working fine. (especially, all the others lights works well).
    I checked the bulbs and fuses : all OK.
    I used the search function to look for threads on this subject but could find same symptoms.
    Could it be a connector issue ?
    Any ideas ?
    Thanks for your help !
  2. Steve Magnusson
    25,149
    Yes, those three bulbs all share a common local ground connection to the chassis -- follow the N (black) wire to where it attaches to the chassis and check/clean/reseat as a first remedy attempt.
  3. F328GTS/GTB
    May 3, 2005
    517
    France
    Denis
    #3 F328GTS/GTB, Jul 23, 2009
    Found what was wrong !
    The upper lights were pushing on the lower lights connectors, when they came down => connectors were not well engaged in each other.
    It was quite easy to fix, but it is strange that so long cables were not better attached to the body ??...
