328 TDC sensor | Page 2 | FerrariChat
328 TDC sensor
Discussion in 'Technical Q&A' started by oporto328, Jan 28, 2008.
  1. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    how much of the other stuff was done at the same time as the problem appeared?
    for example, if the coils were removed, are the connections back in the right place? (e.g. for a 1989, the
    plug with the two red wires should be on the 1-4 bank coil, the one with the red and white wires on
    the 5-8 coil. it doesn't really matter which module the big connector is plugged into...you can swap the connectors
    between modules for testing, but you can't swap the red-red and red-white plugs between coils without
    moving the secondary wire also).
    the comment about checking the sensor and coil harness plugs is also a good one, since those are disconnected
    when the oil cooler air scoop is removed. It's best to check the various resistances and continuity from the ecu connector, which
    then covers those connections as well.
    the flywheel mounting holes are slightly asymetric...someone would have to be quite forceful to mis-orient the flywheel.
    I don't recall if the pegs in the flywheel that the sensors are detecting can be taken out and put back in wrong spots, and
    unfortunately can't find a picture of a 328 flywheel that would show the correct peg orientation wrt the tdc marks, but it seems
    that if the flywheel/pegs were somehow off, the engine wouldn't really run at all.
  2. RGigante
    RGigante F1 Rookie Owner Project Master
    Nov 1, 2006
    2,874
    Portugal
    Update on this problem:
    the flywheel is in fact out of place. The PM mark is aligned for cylinder nº 8, not 1 !!!! Well, it is number 1 on the other bank :-|
    Has anyone ever seen this mistake before ??
