330 GT 2+2 lost keys | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by f40carlo, Jan 3, 2020.
  1. f40carlo
    f40carlo Formula Junior
    Dec 31, 2005
    364
    CANADA
    Carlo
    The place that has stored my 330 GT 2+2 has lost the keys to my car.
    How do I get keys!?...Panicked!
    Serial #9017...single headlight
    HELP!!
    Thank you to all in advance
    Carlo
    ....u can email me [email protected] if u prefer or phone 519 318 4242
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,504
    romano schwabel
    I think carlo needs also the door-, trunk- and gloveboxkey, not only ignition key
  3. BigTex
    79,368
    Houston, Texas
    Bubba
    Glad to help, the Ferrari keys of the era are nothing special.
    I once lost the entire set, as you have:
    You will have to get the ignition switch out, pull it.
    Pull the door cylinder too (just one side)
    Get these to a real locksmith.
    They can disassemble the cylinder and "read" the springs and "housetops", and figure out the cut code of the lost key.
    Same for the door.
    Or, they can also just swap the pins around and make you a fresh key that will render your old ones unusable.
    Might be better, for peace of mind.
    Good luck but all this is exactly my recovery.
    Getting the lock/start switch/column locking rod out was the hardest part.
    My lock guy knew exactly what HE was doing...…...This came out of some foreign car, didn't it??
    Yes sir!
    turbo-joe likes this.
  4. BigTex
    79,368
    Houston, Texas
    Bubba
  5. turbo-joe
    Apr 6, 2008
    9,504
    romano schwabel
    this was is also the most expensive what is no need
  6. donv
    donv Two Time F1 World Champ
    26,050
    Portland, Oregon
    Don
    I assume the shop is paying for this? In which case, "expensive" is just fine...
  7. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    342
    Scottsdale, AZ
    Jim
    Most car dealers run into this problem all the time when customers do not turn in all the keys, they get their contracted "key gut" to come over and make the keys for the locks right on the car. I have had a good key shop insert the proper blank into a 330 and make a copy based on the marks on the blank the lock made. Like stated above the blanks are readily available, and good key guys can make a set in a few minutes on the spot.
  8. turbo-joe
    Apr 6, 2008
    9,504
    romano schwabel
    but only if the inserts of the locks are not too rusty
