Buy
330 GTC Key Fob
Discussion in 'Vintage (thru 365 GTC4)' started by fasthound, Aug 1, 2021.
  1. fasthound
    fasthound Formula Junior
    Nov 23, 2003
    391
    Potomac, Maryland
    Kevin
    Could 330 GTC owners please post photos of their key fobs?
    Does anyone have a verified original?
    My 330 came with a Tiffany art deco style sterling fob which, while nice enough, is clearly not what the car came with.
    Also, I only have one set of keys and need blanks to make another set of keys. Source for blanks?
    Thanks!
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    7,065
    southwest germany
    romano schwabel
    may be in US it is a problem to get blanks. I have here, same as fiat and alfa romeo
    Natkingcolebasket69 likes this.
  4. Oengus
    Oengus F1 Veteran
    8,655
    Between timing belts or FL, SC.
    Chas
    i bought some blanks from a guy off of eBay.....not cheap
  5. JimEakin
    JimEakin Formula Junior
    961
    Mountain Living
    Jim
  6. Zarathustra
    Zarathustra Formula Junior
    794
    Hawaii
    Gary Robinson
  8. Balsamina
    Balsamina Formula Junior
    864
    San Francisco Area
    S
  9. Oengus
    Oengus F1 Veteran
    8,655
    Chas
  10. fasthound
    Nov 23, 2003
    391
    Potomac, Maryland
    Kevin
    You know, I had a couple of those, but one broke and I gave one away to a young nephew who loves Ferraris.
    I also gave away a key fob for my old F430…told him that key would open the door to a Ferrari if he ever found that one car. He was pretty excited.
    PM me and let me know if you’d like to part with one of yours and how much you’d like for it.
    Thanks!
  11. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,072
    Manning, SC
    Robert G. Zambelli
    If there is still interest in this topic, here is a photo of the keys and fob that came with my GTC when I bought it in 1975. The dealer (FAF) assured me that they are original.
    The door key has a white plastic shroud, with a Pininfarina emblem. The plastic is, of course, chipped and discolored from 50+ years of use.
    The ignition key is marked "Neiman" on one side, with a serial/part number on the other side.
    I had both keys duplicated at an Ace hardware store many years ago. Different blanks but they work perfectly.
    I hope this information helps.
    Bob Z.
  13. 375+
    375+ F1 Veteran
    Dec 28, 2005
    8,647
    I have these two. The Lorioli is brand new in the wrapper. The one on the right looks almost identical but does not have a manufacturer's hallmark(knock-off).
    Jack-the-lad likes this.
  14. Jack-the-lad
    Jack-the-lad Four Time F1 World Champ
    49,782
    Isle of Luci
    Jack
  15. BMWairhead
    BMWairhead Formula Junior
    Sep 11, 2009
    966
    Portland, OR
    Ted
    That serial/part number is actually the key code...a locksmith can make a key based on that code and the key shape. It's helpful when a key is significantly worn...a locksmith can make a "new" key instead of copying a worn out key.
  16. turbo-joe
    Apr 6, 2008
    7,065
    southwest germany
    romano schwabel
    right,but you may think that the lock also is old and may be the new key made by the codenumber is not matching right ;)
  17. BMWairhead
    Sep 11, 2009
    966
    Portland, OR
    Ted
    It somewhat depends on the exact tumbler design, but a worn out key with a worn out tumbler sometimes stops working. A new key with the worn tumbler can *sometimes* delay that. Ideally, the locksmith puts new pins or plates in the tumbler AND cuts a new key.
    turbo-joe likes this.
  18. gcalex
    gcalex Formula Junior
    253
    Mostly New Hampshire USA
    Alex
    "Lorioli" fobs of that type I tend to think of as more from the mid/late 70s, and then into the 80s.
    For a 330 GTC, I've gotten the impression that a "Omea"-manufactured fob is more likely to be correct.
    If you just want the general look, "Coinart" makes a similar looking fob, and one sees them for as little as $50 sometimes...
  19. 330BRC
    330BRC Karting
    May 4, 2007
    99
    Seattle, Washington
    Brian Conlan
    fasthound and Jack-the-lad like this.
  20. fasthound
    Nov 23, 2003
    391
    Potomac, Maryland
    Kevin
    when you get a chance, would love to see a photo of the back of the fob. Thanks.
  21. 330BRC
    330BRC Karting
    May 4, 2007
    99
    Seattle, Washington
    Brian Conlan
    Attached is a photo of the back side of the rectangular key fob shown above. It says in small capital letters across the bottom “OMEA MILANO”.
  22. fasthound
    Nov 23, 2003
    391
    Potomac, Maryland
    Kevin
    Thank you!!
  23. 1monza
    1monza Karting
    143
    Manhattan Beach, CA
    Norbert Hofer
    375+ likes this.
  24. enio45
    enio45 Formula 3
    1,130
    Gilbert, AZ
    Ed
    I have that same key fob that came with my 58 Ellena.......
  25. Edward 96GTS
    Edward 96GTS F1 Rookie
    4,554
    i have an AE Lorioli available
    mint cond
