News
348/355 Brake pump conversion kits
Discussion in '348/355' started by User-C3, Mar 5, 2020.
  1. User-C3
    User-C3 Karting
    Aug 29, 2018
    134
    Detroit
    Trevor
    This is something that got started on another thread and thanks to all the members who had blind faith in me coming up with something decent; for that I greatly thank all of you!
    I figured I would start a new thread strictly for the brake pump conversion kit I came up with in case anyone else is interested. This kit will work on all 348 and 355 models equipped with the Teves pump that is a common failure point in these vehicles. I did a ton of research and figured out the Teves pumps found on early Jaguar xj6 and xj12 models are identical at a fraction of the price and readily available with 2 small differences. First the accumulator and pressure line connection are in opposite positions, and the banjo bolt for the pressure line is a larger size. The kit includes everything needed to bolt up one of these Jaguar pumps and places the accumulator lower under the closeout panel to fix the common clearance issue on the factory Ferrari unit.
    List of parts
    Laser cut and yellow zinc coated adapter bracket that matches and relocates the factory Ferrari bracket for mounting the pump with hardware.
    New AC Delco manufactured pressure line to mount from the pump to the vehicles hard line.
    Banjo bolt and copper crush washers for mounting the new pressure line.
    Brake fluid resistant rubber soft line and hose barb for extending the low-pressure fluid feed line from the reservoir without having to remove it.
    Here is a photo of everything I included, a photo of the bracket next to the factory bracket for color comparison, and an installed photo to show the accumulator position.
    308 GTB, jqpd99, Qavion and 4 others like this.
  2. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,234
    Texas
    Jerry
    This is exciting news. Thanks for sharing it.
  3. Ferrarium
    Ferrarium Formula 3
    2,095
    Central NJ
    Eric
    Got my kit sitting in a box with a brand new XJ pump and accumulator for a future need. The kit is great btw.
  4. Carmellini
    Carmellini Karting
    173
    Leo Johns
    I would be interested. how much are the kits? are they "in stock?"
  5. QSA
    QSA Karting
    203
    Kingwood, TX
    Quinn
    I’ll take one.
  6. yelcab
    yelcab F1 Veteran
    Nov 29, 2001
    9,835
    San Carlos, CA
    Mitchell Le
    I see the end of the ******** Ferrari tax where a used Teves pump is $900 and it leaks, a New Old Stock pump is $3,000. Whereas, a used Jaguar Teves pump is $150 and the NOS was $250 (just one).
  7. User-C3
    User-C3 Karting
    Aug 29, 2018
    134
    Detroit
    Trevor
    Qavion likes this.
  8. Carmellini
    Carmellini Karting
    173
    Leo Johns
  9. johnk...
    johnk... F1 Veteran
    Jun 11, 2004
    7,896
    New England/FL
    Certainly professionally done. I hope I never need it.
  10. johnk...
    johnk... F1 Veteran
    Jun 11, 2004
    7,896
    New England/FL
    I wouldn't say it has pitfalls. It just a different approach in that the brake boost is generated by the high pressure pump, not engine vacuum. It was used on a lot of cars, Jag, Alfa, Saab,....
  11. User-C3
    User-C3 Karting
    Aug 29, 2018
    134
    Detroit
    Trevor
    The issue seems to come from the cars sitting and not routinely having the brake fluid flushed. The water content builds in the fluid and tends to seize the pump internal and fry the electric motor. If maintained properly typically its a non issue, but myself and many others have run into the problem. If there is a way to avoid the Ferrari tax and help some fellow owners out in the process I'm all in.
    jjtjr likes this.
  12. Meister
    Meister F1 Veteran
    5,151
    Duluth, MN
    The Meister
    This thread is timely. I just bought a 94 spyder. Car has very little pedal travel and basically no brakes. I have yet to really investigate it but never knew about this pump issue since my previous 348 had no issues.
  13. Wade
    Rossa Subscribed Owner
    Mar 31, 2006
    30,110
    East Central, FL
    Wade O.
    Adding that the newest 348 is 25 years old. So anything that includes moving parts can be expected to fail.
  14. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    14,942
    The Cold North
    Tom
    I have been doing this for years..never a second thought. The Ford super bird unit works great..although they are getting hard to find now.
  15. bjwhite
    bjwhite F1 Rookie
    3,641
    Seattle, WA
    Brian White
    The Buick Reatta pump and accumulator was a very popular replacement in Alfa Milanos (75 RoW). They were dirt cheap. No longer readily available now though.
  16. watkinsgt
    watkinsgt Karting
    Feb 4, 2008
    139
    Thank you for your work on this. Do you happen to have the Jaguar part number(s) necessary for this conversion?
  17. User-C3
    User-C3 Karting
    Aug 29, 2018
    134
    Detroit
    Trevor
    10.0511-9023.1
    I believe this is the jaguar pump part number, found on 1990-94 xj6 and xj12 models. This pump will be the closest to factory. You could do the entire conversion for $400 compared to $1k for a used ferrari pump that may not work.
  18. m.stojanovic
    m.stojanovic Formula 3
    1,779
    Malaysia - KL
    Miroljub Stojanovic
    Jaguar part number for the pump and motor assembly is JLM1884 (NLA from Jaguar). Range Rover P38 has rather similar looking unit, p/n STC2783, but I do not know how easy/difficult it would be to adapt it for the use in 348/355.
    User-C3 likes this.
  19. User-C3
    User-C3 Karting
    Aug 29, 2018
    134
    Detroit
    Trevor
    The range rover unit may be able to be used, but the jaguar pump is the closest to stock. The range rover electric motor will work on the ferrari pump housing if you only need to replace the electric motor.
  20. timeckart
    timeckart Formula Junior
    Apr 9, 2015
    472
    Wildeck in Germany
    Tim Eckart
    With me the brake pump a lot. I found that the relay was broken. Volvo had exactly the same thing. Unfortunately, the engine is now outside due to gearbox damage.
    Is it typical that the relay breaks when the pump is damaged?
    Can you test the pump for damage without the engine running?
    Will the conversion kit still be available in 6 months?
    Can I buy the kit directly?
    Thanks Tim from Germany
  21. User-C3
    User-C3 Karting
    Aug 29, 2018
    134
    Detroit
    Trevor
    I don't think the relay issue is from a bad pump. That could be more of a wiring issue. The pump assembly can be bench tested by simply puting power and ground to the electric motor. However this may confirm the pump spins but doesn't mean the pump is able to build pressure.
    I figured an eBay listing would make purchasing easier for people, but if anyone wants to buy one directly simply send me an email
    Tmantkus@yahoo.com
  22. m.stojanovic
    1,779
    Malaysia - KL
    Miroljub Stojanovic
    The pump relay contacts can burn if the ABS Pump has seized. The stalled motor will draw very high current affecting the relay. Bench test the whole assembly (pump & motor) by briefly touching the motor wires with 12V supply. If the motor does not run, your pump has probably seized or it could be seized motor but unlikely. You can then detach the motor and test it separately.
  23. timeckart
    Apr 9, 2015
    472
    Wildeck in Germany
    Tim Eckart
    OK Thank you.
  24. User-C3
    User-C3 Karting
    Aug 29, 2018
    134
    Detroit
    Trevor
    I was finally able to get a good photo of the bracket kit and Jag pump fully installed without the closeout paneling around it. This pump is working flawlessly as one would expect out of their braking system.
