348 Cam Chain Tensioner Pad | FerrariChat
Discussion in '348/355' started by PaulWM, Mar 14, 2016.
  1. PaulWM
    PaulWM Rookie
    Feb 7, 2016
    2
    #1 PaulWM, Mar 14, 2016
    I have recently acquired a 348 and have been performing major service on it. Attached find a picture of the Cam Chain Tensioner Pad showing the wear. The grooves where the sidebars run are approx .070 deep and where the rollers run about .040 deep. Total thickness at the high point of the pad was initially .300, so this leaves me about .23 at the grooves and .26 under the rollers.
    I have no idea if it has ever been replaced, but there are approx 70K miles on the car.
    I would expect the initial grooves at the sidebars to form quickly and the wear rate to slow down once the rollers come into contact. Can anyone guess from the wear if it has been replaced or how many miles might be on it? Also, how much wear can be tolerated before this relatively expensive part requires replacement?
  2. LorenzoR
    LorenzoR F1 Rookie
    I cant say but I don't think its worth the chance. Id just bite the bullet and put on a new one while its out. Also I think there was a recent thread where someone was replacing one.
  3. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    #3 ///Mike, Mar 14, 2016
    That looks pretty darned good if it really has 70k miles on it. No way that I know of to tell for certain, but if you happen to have an early car before the factory drive bearing update one clue would be whether or not that bearing has been changed in your car. If it has been updated there's a chance that the tensioner was replaced at the same time. If the bearing has not been updated then perhaps no one has even been that deep into the engine. I'd be curious either way, as I'm trying to get a sense of how long those tensioners and either version of the bearings last.
    Another clue is the color of the material itself. Assuming it started out off-white one can safely assume that it's been in the engine for some time to have acquired the darker hue.
    In any case, I think it's false economy to be that deep into the engine and not replace the tensioner, as well as the infamous bearing. As you probably know, Hill Engineering recently released an upgraded bearing and I think I've read here that Dave Helms offers a better tensioner, or at least an upgraded pad.
    As an aside, while I've never seen it posted here, there is apparently some concern that the pad base can separate from the plunger, as I was once asked by a customer to strengthen that joint by adding some tack welds (see attached, which I'm guessing is from the tensioner under discussion). Seems like a worthwhile safety measure "while yer in there".
  4. itsablurr
    itsablurr Formula 3
    Dec 9, 2005
    1,010
    Carlisle, MA
    Matt
    What year for your 348 and engine assy#, chassis #? Believe the updated material is from engine/chassis assy 24720 / 4384
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    #5 ernie, Mar 14, 2016
    That timing chain wear pad is done, replace it. The updated pad material you want is made from Stanyl PA46 TW341. The company that manufactures Stanyl is DSM, from the Netherlands.
    F1Flaherty likes this.
  6. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
  7. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Can anybody send me ( to Belgium) a worn , bad piece from each of the 2 pads for taking measurements. I know maybe a shop who can fabricate them out of TW371.
    Grts
    Patrick
  8. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Of course i will pay for shipping.
  9. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    I think I still have my old stuff. I will have a look for it and let you know if I can locate it.
  10. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Thx
  11. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Hi Ernie, did already had time to look for the pads ?
  12. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,189
    Atlanta
    John!
  13. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    I know . Now just try to buy it. :-(
  14. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Sorry Patrick, I was really busy over Christmas weekend. I’ll have a look and let you know by tomorrow.
  15. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    Yeah but the other info I have is even better stuff. I thought I gave it to you??? It’s still made by DSM, but is their newest material.
  16. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Yeah It is called TW 371. The only problem is i can't buy either of them. DSM only selling the granulate , not solid form. I found an distributor here in Belgium called ; Quadrant. They have also high tec plastics in rod or plate form. But they are still closed for the hollidays. I will ask them if they can deliver this material or equal.
    I am planning an engine out major service beginning next year , when i have my lift, so i am starting looking for al the parts needed.As my 348 has 60.000 km i think the pads will be worn.
  17. Ferraripilot
    May 10, 2006
    17,189
    Atlanta
    John!
    Granulate is no problem. We'll make it work. thanks for clarifying Ernie
  18. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    No, that is not the stuff I'm talking about. DSM make a whole bunch of different plastics for different applications.
  19. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    You go it John.
  20. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    What "stuff" do you mean Ernie ??
  21. ernie
    Nov 19, 2001
    22,576
    The Brickyard
    The Bad Guy
    I looked for the worn pads the other day and didn't find them.
  22. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    That's a shame. Ordered in the meanwhile this one on eBay to compare. From Land Rover. 12 euro
    I have read in an old topic from you Ernie that this is not a Ferrari part but made by a company in France or something.
  23. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Also from eBay, a piece of Pa4.6. It looks identical material to Stanyl and that what Dave Helms had used for his first test.He found an even better material but this can work also very good i think. Color i correcter in real life. More Brown.
  24. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,597
    Maryland
    David
    Sorry a little late to the game. I have my worn pad if you still need one. just let me know.
  25. Cauf61
    Jul 12, 2016
    557
    Belgium
    Patrick
    Yes That would be great.
    How to ship ? Can you put it in an envelop by post ? I will pay of course the cost.
