348 Cam Drive Chain Tensioner. | Page 2 | FerrariChat
Discussion in '348/355' started by steved033, Feb 5, 2019.
  1. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,365
    Atlanta, GA
    Steve D.
    do you have a picture?
  2. Aris64
    Aris64 Karting
    Feb 26, 2024
    79
    Greece
    Aris Arvanitakis
    I will take tomorrow a of the plug. I decided and fixed the tensioner without it as certainly was blocking oil's flow through the tiny hole.
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    Was the spring maybe installed the wrong way around by the PO?
  4. Aris64
    Aris64 Karting
    Feb 26, 2024
    79
    Greece
    Aris Arvanitakis
    I borrowed the photo from @ernie , I have the same exactly setup. My question is what serves the plastic pin at the bottom of the spring. The way that is fitted I think is blocking the oil flow from the tiny hole on the pad surface. That's my point.... It would be better to remove the pin? The spring will be less loaded but it is supposed thathe oil pressure do the job. From the other hand the designer of Renold should be smarter than me....
  5. m.stojanovic
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    This is a similar (different pad) Renold tensioner that I have. It has an oiling hole through the pad and it is for Peugeot, no plastic pin.
    The plastic pin (just guessing) might be there for two reasons: 1. to increase the spring tension (if some existing Renold spring, designed for another car, was adopted instead of ordering a 348 specific one) and 2. to make the rotation of the ratchet and spring easier when the extension of the pad is auto-adjusted.
    On the other hand, are you sure that the plastic pin totally blocks the oil flow through the pad? Are there any slots in the face of the plastic pin, or any slots at the bottom of the tubular part attached to the pad?
  6. Aris64
    Aris64 Karting
    Feb 26, 2024
    79
    Greece
    Aris Arvanitakis
    I will recheck... It seems that bottom of the cylinder is a little bit concave so oil may pass.
  7. cstorry
    cstorry Karting
    Apr 28, 2005
    91
    Ottawa, Ontario
    Chuck Storry
    ernie likes this.
  8. cstorry
    cstorry Karting
    Apr 28, 2005
    91
    Ottawa, Ontario
    Chuck Storry
    Does anybody else see huge wear on these replacement pads ? (or is it too soon to tell because you haven't done a 2nd major after putting this pad in so don't know how badly they are worn). According to threads I am reading about the lack of availability for 147338 it seems like this was discussed around 2018-2020.
    Mine only has 500 miles on it and it looks nearly worn out to me. If it wasn't for my broken waterpump (also only 500 miles after major done) I would not have seen this. (long story but totally disassembled motor to find and clean out missing bits of the waterpump so checking everything while there)
    Is Scuderia Rampant still selling these pads? Guess I need to call/email them.
    I've heard their pads are a different material but no information related to tensioners on their website.
    I'm reluctant to just replace the pad with another of the same type for obvious reason.
  9. fdekeu
    fdekeu Formula Junior
    633
    Belzium
    Frank
    Probably the material used for the tensioner pad is a different type of plastic
    Less wear resistant
    Needs to be a specifiic type of PA (Nylon)
  10. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    The name is Stanyl PA46 TW341. That is what the tensioner pad should have been made of. But by the look of that photo it definitely was not.
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Why waste your time and money?
    When The RovahFarm still has the tensioner (reference number ETC5190) for sale at $27.95 a pop as of this post.
    https://rovahfarm.com/defenderengine25NApg4.htm
    fdekeu likes this.
  12. m.stojanovic
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    ernie likes this.
  13. m.stojanovic
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    Looks like it either overheated and melted, or ran dry, or both. Is there an oiling hole at the bottom of the tubular part and through the pad?
  14. cstorry
    cstorry Karting
    Apr 28, 2005
    91
    Ottawa, Ontario
    Chuck Storry
    Agreed - melted for some reason.
    there’s no hole in the yellow/orange plastic button but the metal holder has a hole and the black tensioner appears to have a hole on the back. It’s hard to tell on the front because it’s melted but I think so.
  15. fatbillybob
    Aug 10, 2002
    29,274
    socal
    Pa46 is a nylon. I wonder how delrin would hold up?
  16. m.stojanovic
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    The Renolds Land Rover tensioner ETC5190 does not have an oiling hole through the pad so one would have to be drilled.
    ernie likes this.
  17. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    If Delrin would have held up they would have used it instead of Stanyl.
  18. fatbillybob
    Aug 10, 2002
    29,274
    socal
    not necessarily…one could have been cheaper but acceptable or easier to manufacture.
