348 clutch not hold pressure when engaged . | FerrariChat
Discussion in '348/355' started by Sib0099, Mar 12, 2025.
Tags:
  1. Sib0099
    Sib0099 Rookie
    Oct 29, 2017
    23
    Kansas City
    Sib Deliscious
    Recently the clutch on my 348ts has started to slowly engage while pushed in. Like if I’m at a stop light in gear with the clutch pushed in after a few seconds the clutch starts to engage while the pedal is still down. If I’m driving the pedal pressure feels regular and it shifts just fine. It’s when I’m sitting with the clutch in.
    No leaks in the rear of the car. However it seems to be pushing out fluid from the overflow tube on the reservoir . I’ve checked the master cylinder for leaks and the lines up front. No fluid anywhere. I’ve bled the clutch several times and no air in the lines. Any ideas?
    This is a newer clutch, and throw out bearing.
  2. fdekeu
    fdekeu Formula Junior
    631
    Belzium
    Frank
    There is an internal leak in the master
    Change the seals
    IvanRico likes this.
  3. innerloop
    innerloop Formula Junior
    Jan 17, 2010
    260
    Houston Heights, TX
    I would agree as I had the same problem a few years ago. I changed to a new master and everything was fine.
    fdekeu likes this.
  4. Sib0099
    Sib0099 Rookie
    Oct 29, 2017
    23
    Kansas City
    Sib Deliscious
    A leak in the clutch master cylinder or the fluid reservoir? Sorry for my ignorance. Is the clutch master cylinder the same as the clutch slave cylinder?
