348 Door Connector - AMP | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by reado10, Jun 15, 2011.
  1. GavC
    GavC Formula Junior
    May 9, 2004
    492
    Lincolnshire, Englan
    Gavin Culshaw
    Try Farnell.com for AMP connectors or equivalent. We use these on a multitude of engines that I sell for different manufacturers. FPT (Fiat Powertrains Technologies) being one which is the Diesel division of Fiat and Ferrari. Just be careful with the pins when crimping.
    Good Luck
  2. fana355france
    fana355france Formula Junior
    284
    France
    nicolas
    Hello !
    very nice tech documents.
    Do you know where I can buy this connector ? I only need the big locking nut on the fender connector.
    thanks
  3. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    revisiting this post... I have the connectors but what about the crimper for the job?
    any recommendations?
  4. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    Ferrari has always had part numbers for these electrical connectors but you had to know to look in the Electrical Components catalog.
    They are all still currently available. Male door connector is $16.26, female connector is $14.04. Male terminal is $1.00 and female terminal is $5.98.
    Rutlands has them in stock.
  5. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Thanks... but i need to know the tool. Digi key has one te amp for $712... ouch
    Sent from my SM-G965U using Tapatalk
  6. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I'll try to remember to look at the one I used. After seeing how much the proper tool costs I set about to find another option. Think I got mine on Amazon, and I was pleased with the results after I taught myself how to use it.
    I've just reattached broken wires at this point but I believe a proper fix would be to extend each of the wires several inches using silicone jacket wiring (for flexibility) before attaching the terminals. I can't help but think that if all of the wire that flexes when the door moves is silicone, and if the area immediately aft of the terminals is strengthened with heat shrink, the wiring flex will be spread over a large enough area to not pose a problem again in my lifetime.
    BTW, make your own pin-out chart! The one posted in the 348 section did not match my car. I can post mine in that thread though, if you think it will help.
  7. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    if you can recall that tool.. that would be great....
  8. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    I accidentally remembered to look at it because I was standing in the shop office last night and saw it sitting on a file cabinet. Otherwise I would have completely forgotten about it, such is my memory.
    I used a Hozan p-706. Here's a link: https://www.amazon.com/Hozan-P-706-Open-Barrel-Crimper/dp/B002TKG11G/ref=sr_1_1?ie=UTF8&qid=1529891201&sr=8-1&keywords=hozan+p-706
    I did a couple of test pins indoors in good light to get a good feel for the tool and what size crimps are needed. It doesn't look like much but it's capable of quite decent crimps if you use the correct size and keep the terminal in the exact right position to ensure that the pointy part of the die winds up centered on the terminal during the final part of the process. I was happy with the results and everything worked after the repair. :)
    HTH.
  9. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Thanks so much! that looks like it will work just fine.
    I have the connectors and the wiring is a mess in there... another wire came loose yesterday when I was in there poking around trying to find a parasitic draw (didn't find one).
    Now to source the various colors of wiring. I think I'm going to put all new wiring into the connector and then splice in the door. Should be a fun project. ;)
  10. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Sounds like a plan. That's what I want to do with mine, but too many projects & not enough time.
    I'd suggest using silicone jacket wire. If you haven't played with any you won't believe how flexible it is. It's expensive, but it's nice to work with and the added flexibility should take a whole bunch of stress off of the area immediately aft of the terminal. Seriously, the stuff is like wet spaghetti. :)
    Downside is I doubt you'd be able to find it in the proper colors so you'd have to adapt the color scheme. If you're committed to using the OE colors try these guys:
    https://www.autoelectricsupplies.co.uk/category/10
    http://www.vehicle-wiring-products.eu/section.php/198/1/single-core-pvc-thin-wall-cable
  11. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    Mike,
    Can you provide the color coding of the pinout? Would be much appreciated. I am going to try and just re-do all the wires. I am assuming that I will just keep having this issue if I don't.
