348 engine out major | Page 16 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #376 ernie, Feb 27, 2014
  2. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    Nope.
    Put I them in cold.
  3. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #378 ernie, Feb 27, 2014
  4. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #379 ernie, Feb 27, 2014
    The second reason I initially only put the cover on part ay is because, I do not want to risk causing the crank seal to go on wrong. I do not want the lip on the back of the seal to get folded over.
    So what I did was GENTLY help the seal over the crank using a plastic wedge. As I went around the lip of the crank seal I SLOWLY and GENTLY pushed the cover on. I was very careful, and took my sweet time king this, making sure NOT to force it.
  5. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #380 ernie, Feb 27, 2014
    And here is the crank seal installed, safe and sound.
    Notice the arrow, on the side of the seal, is pointing clockwise, the rotation of the engine.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Did you release the tensioner(s)?
  7. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #382 ernie, Feb 27, 2014
  8. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    Coming right up. ;)
  9. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #384 ernie, Feb 27, 2014
    To do this I inserted a screwdriver into the slot on the backend of the release/retaining shaft. Then I twisted it slowly, counterclockwise, until the keyway on the tension block fit over the locking portion of the shaft, releasing the spring, and placing tension on the oil pump chain.
    VIOLA!
    I did this bit last, as I wanted the cover to be secured to the block first.
  10. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    Gonna take a break now. I'll be back later to post up some more stuff.
  11. ceb39
    ceb39 Formula Junior
    Sep 17, 2012
    483
    San Francisco Area
    Chuck B
    A couple of questions:
    1. In the above photo how many hours into this project at that point?
    2. Do you write down the steps to take the engine out, so you can do them in reverse when you go to put the engine back in?
    3. Like the tires. Where did you buy them, and what size are they?
    4. Keep us informed of the condtion of the various rubber parts you can see with the engine out. Do you plan on replacing any?
    Now I know why my mechanic told me to stick with my Mondial, and not go with a 348. But one day I will throw that idea to the wind and buy one, I love the looks of them.
    ceb39
  12. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    I haven't been keeping track.
    Nope.
    I assume you mean the wheels. Bought them from a fellow fchatter. 18" F355 wheels.
    If it ain't broke, don't fix it.
  13. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    Outstanding work my friend. Surprised and relieved to the relative simplicity of the design. Have not see you needing any factory or specialized tools up to this point which is awesome.
    I am really interested whether there is an aluminum alternative to the plastic water pump impeller.
  14. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    As far as tool go, yeah, nothing really special. I think the most expensive tool I used was the cherry picker. But, that was a special circumstance because I pulled the engine off the subframe. Other than that nothing really fancy.
  15. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #390 ernie, Feb 28, 2014
  16. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #391 ernie, Feb 28, 2014
    I found it's a good idea to install the cam belt tensioner bearing first. The reason is I find it easier to compress the spring. I can use my weight to push the bearing into the housing.
    I install the tensioner housing on the the block loosely. I don't tighten the nuts all the way, and leave a little gap.
  17. fatbillybob
    Aug 10, 2002
    29,287
    socal
    That is a non-issue. The more important issue is what to do about the unavailable timing cover bearing. I would be keeping a very very close eye on that if a current OEM bearing is being used. I would have considered a rebuild of the old bearing or custom sourcing/modification by someone like spherics, (Gardena,Ca.). As an example once Reiner ,the inventor of taking the engine out without a lift, had a hard time sourcing one of the tranny cover bearings and spherics made a less expensive solution that is now the "reiner bearing."
  18. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #393 ernie, Feb 28, 2014
    If you look you can see a slot just behind the back of the tensioner. That slot is for the bearing stop-dowel on the back of the tensioner to fit into. If you look at the 2nd photo in the side by side comparison you can see the stop on the back of the tensioner bearings.
    This is why I don't tighten down the nuts on the bracket. It leaves me a little bit of play room to get the dowel in the stop groove.
    After I have the bearing in the housing, with the stop-dowel successfully in the groove, I then tighten down the 3 nuts securing the housing to the block.
  19. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #394 ernie, Feb 28, 2014
  20. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #395 ernie, Feb 28, 2014
    With the tensioner bearing secured in a compressed state I will now install the water pump.
    First up the connecting hose, and clamps, get fitted to the cross over pipe. If you try and do this after the water pump is in place it's a pain.
    I'm reusing the old hose. I know, I know, I should buy a new one. But it still felt fine, and if it ain't broke, don't fix it.
  21. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #396 ernie, Feb 28, 2014
  22. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #397 ernie, Feb 28, 2014
    Here you see two different size bolts, one shorter than the other. Both of which get used to hold the pump to the block. But which one goes where?
  23. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #398 ernie, Feb 28, 2014
  24. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #399 ernie, Feb 28, 2014
    And the two shorter bolts you can see I already threaded in here.
    So be sure to make sure you have the correct bolt lengths in the correct holes.
  25. ernie
    Nov 19, 2001
    22,621
    The Brickyard
    The Bad Guy
    #400 ernie, Feb 28, 2014
    Now to double check this I tighten them down all the way by hand, using my fingers. If one of them doesn't thread all the way in, and I can get it to thread all the way in with the force of my fingers, then I must have the wrong bolt in the wrong hole. If they thread all the way in with my fingers, then I'm good to go and finish tightening them down the an allen wrench.
