348 engine out major | Page 27 | FerrariChat
Discussion in 'Technical Q&A' started by ernie, Feb 22, 2014.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    :D
    Sorry bro, but yeah.
  2. since-15
    since-15 Formula 3
    Nov 26, 2008
    1,142
    WOW!!! Impressive!
  3. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Wanted to give you all an interesting update.
    Out of curiosity, and to see how the engine is running, I took it to get dyno'd today. The result? I LOST -5hp :eek:, but I gained +1tq. The hp lines are virtually identical. On the old stretched out belt I made 305hp to the hubs at 7200rpm. On the new belt timed to the factory marks, for a car with cats, it made 300hp @ 7000rpm. Under the curve I did make a little bit more torque, I think mainly due to my new 3.8bar/55.1 psi FPRs. Peak tq for both the old belt and the new belt came at 6000rpm, with the new belt make 234lbft, and the old belt making 233lbft. All power was measured to the hubs.
    It's my guess that the old stretched belt retarded the cam timing so that is what "similar" to the Competizione cam timing.
    All my "go fast parts" were the same, the main difference was the cam timing and FPRs.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    So you would believe that the dyno from 6 months ago performed the same way 6 months after and that its accuracy is well within the 1.6% discrepancy?
  5. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Had that been the only two dyno's, no. But seeing that I've dozen of pulls at Church's, both before and after of various setups, I do believe it.
    Oh and,
    Their margin of error is 0.50%, or something like that.
  6. yelcab
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    Well, that is better than my torque wrench.
  7. flxzcat
    flxzcat Karting
    Sep 16, 2008
    143
    lake forest, ca.
    paul van der linden
    Could you be running too rich with the new FPR?
    Paul
  8. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Possible but not likely. Last run of dyno pulls my afr at wot was around 12.8:1-13:1 on the top end, and 13.6:1-14:1 in the mid range. So the high pressure actually is what gave me a bit better tq in the midrange and +1peak. This pull we didn't have the sniffer in the tail pipe, guess we should have, but I'm not too worried about it. I honestly believe it has to do with the cam timing, specially since my peak hp dropped lower in the rpm band by 200rpm.
    When I had the engine out and on a stand I TRIED to book some time on an engine dyno. That way I could have seen what it was putting down at the crank, and fooled with the cam timing a bit. But I had no such luck finding a place in So Cali that was set up for doing such a thing, or even willing to, for a Ferrari engine.
    Still not disappointed, as my engine is pretty daggon consistent.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    If you find someone let me know
    Gary at Illmore in Plymouth Michigan is all I know of
  10. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Carobu Engineering in New Mexico is the closest place I know of.
  11. flxzcat
    flxzcat Karting
    Sep 16, 2008
    143
    lake forest, ca.
    paul van der linden
    Might be these guys unless they have moved to NM
    Dyno Testing
  12. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    They moved to NM.
  13. flxzcat
    flxzcat Karting
    Sep 16, 2008
    143
    lake forest, ca.
    paul van der linden
    Huh, must be an old website. Anyway I realize its too late.
  14. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #664 ernie, Oct 4, 2014
  15. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,244
    Worcester, England
    Phill J
    Mmmmmm.......As it's a Ferrari do you have to use Coca~Cola cans or can you use cheaper supermarket brand Cola cans instead? :confused:
    (I'm just thinking about those trying to run their 348's on a tight budget! :p )
  16. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Sometimes you just have to bite the bullet and pay for quality. :p
  17. Cooper
    Cooper Karting
    Feb 25, 2013
    227
    London, Ontario
    Chris Cooper
    Wow this thread was crazy, we are going to do a Major to Acemasters next week and this was perfect. I know you talked to mike, we are going to do it off a 4 post lift with rails. Thx Ernie, you may get a call from Mike! Cheers!
    ernie likes this.
  18. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #668 ernie, Apr 1, 2015
  19. fatbillybob
    Aug 10, 2002
    28,642
    socal
    I like the coke can! That should be Plugzit's signature for every major he does. He must drink hundreds of gallons of coke per year.
    ernie likes this.
  20. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    I thought it was diet coke? And yeah, he drinks loads of it.
  21. PinoyP
    PinoyP Formula 3
    Aug 7, 2006
    1,023
    Bay Area
    AL
    ernie likes this.
  22. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,522
    Jeff
    Really enjoyed the video.
    Just a suggestion though - ave you thought of adding a commentary instead of the music? Would make it even more useful???? :)
  23. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    #673 ernie, Feb 12, 2016
    LOVE the video! That was GREAT!
    Nice job getting it out, and thanks for making the video. Here it is imbedded.
    [ame]http://www.youtube.com/watch?v=AS8daX_BtUg[/ame]
    Again good job Al, Stooges rule!
  24. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,237
    Austin, TX
    Randy
    Great video! Make sure to do another putting the engine back in. It's great to see a major being done in a normal garage with hand tools.
  25. yelcab
    Nov 29, 2001
    13,416
    San Carlos, CA
    Mitchell Le
    All I saw was him removing the wheels and the bumper. How did he get it out?:
