348 flywheel nut help | FerrariChat
Discussion in '348/355' started by grigio tr, Oct 2, 2009.
  1. grigio tr
    grigio tr Rookie
    Jan 30, 2008
    41
    east sussex, UK
    mike
    removed pumpkin to replace clutch,triple seals and regrease flywheel etc and found the ring nut holding the flywheel has been butchered by a previous mechanic making it difficult for the hills engineering tool to make a good fit,it looks like its been attacked with a hammer and chisel!! My dilema is (knowing how tight they can be) do i risk damaging my ring nut tool in a possible ill fated removal attempt with impact gun or go straight in with an air chisel and hope for the best? Anyone else had same experience and / or any help or advice would be greatly appreciated
  2. Saint Bastage
    Saint Bastage F1 Rookie
    Jun 1, 2007
    2,548
    Connecticut
    Lane
    Never done the job but the risks seems to be fairly clear.
    Risk damaging a tool or risk damaging a shaft and flywheel.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    You may end up having to weld a hex nut, or perhaps a heavy duty socket, onto the damaged ring nut, in order to remove the ring nut with a conventional socket and an impact wrench, or a breaker bar. Sounds like you need a new ring nut anyway. Good luck with it, don't do anything to bung up the threads.
  4. PAP 348
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    +1!! Either flog the **** out of it with a chisel and hammer to get it off..............or weld another nut onto it and get if off that way. :D:D
    You will need a new nut either way. ;);)
  5. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I bought the Hill ring nut tool, and my 2cents are that it seems to be made of extremely hard material, so I think the nut will give before the tool is really damaged. At least you could try the tool a bit and check before going further. Good luck :)
  6. grigio tr
    grigio tr Rookie
    Jan 30, 2008
    41
    east sussex, UK
    mike
    Thanks for the advice guys,i've got a new ring nut from hills in readyness.Will be doing this
    in a friends workshop within the next few days.The sharp edges of the damaged ringnut have started to wear the 4 pins in the ring nut tool ever so slightly so i know i could be heading for disaster,might just go for it anyway first and order another tool if i wreck it,the idea of welding an old socket / hex nut onto the ring nut first sounds like a good plan!
    Will post up details of how it goes later..
    the mechanic who had this all apart before wants shooting,not only was the ring nut damaged,the pumpkin wasnt seated on the gearbox correctly due to one of the dowels being crushed when it was put back together! there was around 1mm gap halfway round between pumpkin and gearbox!!..explains the slightly uneven wear on the clutch plates!
  7. PAP 348
    Dec 10, 2005
    100,216
    Pap
    WHHHHHHHHOOOOOOOOAAAAAAAAA!!!!!!!!!!!!! :eek::eek:
    That mechanic needs rooting!! :mad::mad:
  8. grigio tr
    grigio tr Rookie
    Jan 30, 2008
    41
    east sussex, UK
    mike
    If i find out who it is i will name and shame :)
    all this bother because of the small issue of not wanting to start very easily when warm!
  9. PAP 348
    Dec 10, 2005
    100,216
    Pap
    I hope so! ;);)
  10. grigio tr
    grigio tr Rookie
    Jan 30, 2008
    41
    east sussex, UK
    mike
    #10 grigio tr, Oct 3, 2009
    took your advice Pap and went for it with large hammer and chisel! after some swearing,blood,sweat and tears it came off!,,amazingly i didnt do any further damage even to the ring nut!
    the ring nut was in this condition when i removed the cover on the pumpkin!
  11. grigio tr
    grigio tr Rookie
    Jan 30, 2008
    41
    east sussex, UK
    mike
    Many thanks for your quick replies in helping me out guys,im happy now since my flywheel assembly is in one piece still and not broken.Just waiting for the grease and triple seals to arrive on my doorstep so i can carry on.
  12. PAP 348
    Dec 10, 2005
    100,216
    Pap
    Wow! That nut was VERY beat up! :p:p
    Looks like it was chiseled off many times before?? :rolleyes::rolleyes:
    Man there are some rough ****s out there! :p:p
    Good man! Have fun! :):)
