348 - 348 gearbox behavior | FerrariChat
348 348 gearbox behavior
Discussion in '348/355' started by raoulfilippi, Jan 13, 2020.
  1. raoulfilippi
    raoulfilippi Karting
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    Hi guys, lately the gearbox of my 348 is showing a strange behavior. When i pass from second to third gear i receive two responses. If I release the second, pass to neutral and then i insert the third gear all is working fine, but if i try to change in “sport” mode, passing directly in a unique movement between the two gears, the inserption of the third gear seems bit “harder and skidy to insert”. (Difficult to explain in simple words)
    The opposite action, I mean from third to second, is ok, and also the movement from fourth to third gear appears fine. Anyone of you has noticed the same mechanical backlash? what could it be?Bearings?
    Thx for your opinion
    Inviato dal mio iPad utilizzando Tapatalk
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    I would check the condition of the bearings on the main and lay shaft, also the condition of the ring nuts, especially on the gearbox oil pump side of the shaft.
    raoulfilippi likes this.
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I know the ring nut under the TOB, but the one you mention, is it behind an access plate accessible with wheel off?
  4. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    thanks for the suggestion, I'm gonna ask to the mechanic to check it out.
    Is it an operation that suppose to just disconnect the gearbox, or should it be totally opened?
    Inviato dal mio iPhone utilizzando Tapatalk
  5. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Ernie knows way more about this than me, but if after checking out his recommendations, you find nothing wrong, just for laughs, try lubricating your shift cables if that's never been done:
    Unlikely to help in this situation, but it won't hurt, and it will ensure you double check the nuts, bolts and joints where the cables attach to the shift lever and transmission mechanisms.
    Sent from my VS990 using FerrariChat.com mobile app
  6. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    Thanks a lot. This will be surely done. If possible I’d like to know if the bearings to be controlled are inside the box or if can be inspected just by loosen the shafts from the rest of the structure.
  7. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    These bearings are on the passenger side of the gearbox.
    You have to remove the transmission and the side cover.
    But then you only see a little bit of the outer balls of the bearing and if you want to really inspect them you have to remove them.
    To remove the bearings you only need to remove their casing on the side and the rest of the gearbox is not touched.
    But your symptoms make me think more about a synchro ring or adjustment issue?
    A bearing would be more like a constant noise?
  8. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    Hi, thanks. Probably is how you have said. At the end I won’t be surprised in will be a synchro ring to replace.
    This means open the box (with the price increasing indeed, not for the ring itself but for the price of the labour)
    If confirmed, in September I’ll proceed to dismount the box and change the ring.
    In the meanwhile the car is still usable whit the proper care.
    paulchua likes this.
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  10. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,040
    Atlanta, GA
    Steve D.
  11. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    Don’t understand what’s the problem with the filter. You mean just for the removal?
  12. steved033
    Apr 12, 2017
    10,040
    Atlanta, GA
    Steve D.
    most filters of any sort have some maintenance schedule. I can't find any information on the gearbox filter.
    sjd
  13. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    The gearbox filter is a plastic bag filter and I don't think it needs to be changed, just cleaned when the oil pump casing is opened since its aim is only to catch metal chips.
    Anyway it is not anymore produced and really hard to find..
  14. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    Ok, gotcha. You are referring to the magnetic trap,right?
  15. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    steved033 likes this.
  16. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    In order to get to the ring nuts and outer bearings you will need to remove the gearbox. Run a search of the archives to see the damage that gets done to the ball bearing cages.
  17. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
    Thanks a lot
  18. raoulfilippi
    Sep 28, 2018
    71
    Bologna-Italy
    Raoul Filippi
  19. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    If you inspect the oil pump side bearing then you will have the oil filter in your hand like on my picture.
    I don't know if it will help a lot.
    I found some aluminium chips in my filter but a part from that my gearbox was perfect and found others example like mine speaking about machining chips.
  20. Swallowtail
    Swallowtail Rookie
    Dec 7, 2020
    30
    I would love to get some more info on how to inspect/remove the filter. I'm planning an gear oil change in the near future and would love to clean the mesh filter at the same time.
