348 Hub Nut Size | FerrariChat
348 Hub Nut Size
Discussion in 'Technical Q&A' started by kenyon, Dec 22, 2003.
  1. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
    Guys,
    can anyone tell me the size in mm of the main rear hub nut ??
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    I assume you are refering to the large nut that screws onto the drive shaft that secures the rear hub bearing, the actual nut measures 35.85mm so a 36mm socket will do the job - the torque figure is
    275 Nm
    MW
  3. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
    Thanks, sorted....
