348 Induction System | FerrariChat
Discussion in 'Technical Q&A' started by MarkCollins, Dec 9, 2003.
  1. MarkCollins
    MarkCollins F1 Rookie
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    I'm trying to understand how it works or more specifically what the additional butterfly is for. It is sited between the two banks and seems ot be controlled by a Vacuum valve
    Anybody know what it is for or when it opens and why
    thanks
  2. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    Wave tuning the intake air. Separate banks at lower rpm for improved torque, open plenum for high rpm power.
    Can't remember specific opening protocol. It's in WSM.
    Best regards,
    Rob Schermerhorn
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Mark: Try to find yourself a copy of Enrico Benzing's book on the 348, in the "Automobilia" series. It is/was available in both hardback and paperback, and it has a lot of good information on the design of the car, including a great description of the manifolding system.
    I was also looking at the "Ferrari Story" issue on the 348 for details about the manifolds, and I was amused to see the quote that the Bosch Motronic system "....uses the hot wive device for measuring the air flow." Sounds like a tempermental component to me.
  4. Etcetera
    Etcetera Two Time F1 World Champ
    23,926
    C6H14O5
    Miltonian,
    That wire you speak of is the Mass Airflow Sensor. It is given constant voltage, which heats the wire. Air flowing through the channel that it is in cools it, dropping its resistance and allowing more current to flow through it. More current must then be applied to keep the wire at a constant temperature. These changes in current are then interpreted by the computer as airflow.
    A pretty simple system, and it works fairly well!
  5. MarkCollins
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    Thanks for the replies
    I think Korr was referring to a typo where it states it uses a 'hot wive'
  6. Etcetera
    23,926
    C6H14O5
    I see, my apologies, then!
    I can be tragically daft in the morning.
  7. Etcetera
    23,926
    C6H14O5
    I'm glad my brakes don't fade as much as my brain does in the morning!
  8. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,710
    Both chambers the feed each bank are Helmholtz resonators, and are turned for the upper end of the rev range. The valve that connects the two resonators alters the resonance point for better TQ in the lower end of the rev range.
    Do a google on "helmholtz resonators" and "engine tuning"
  9. MarkCollins
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    Mitch
    thanks for that, now I need to find out what controls it ie what tells it to open and whilst I can see it is Vacuum driven I'm wondering if there is a solenoid in the line and that the ECU(s) controls
