348 KickPlate remove and install | FerrariChat
Discussion in 'Technical Q&A' started by colo348, Nov 22, 2003.
  1. colo348
    colo348 Karting
    Nov 1, 2003
    143
    Colorado
    Jim
    #1 colo348, Nov 22, 2003
    Hi 348'ers,
    The attached image shows the passenger side kickplate. Does anyone have experience with removal and installation of this item? I can see the screws and how it could come out, but any insight is always a great help.
    Thanks in advance,
    Jim Hilton
  2. 348paul
    348paul Formula 3
    Dec 27, 2002
    1,098
    Kent - UK
    Paul Hill
    Jim,
    Just remove the screws and pull toward you. There is a lip that wraps round at the front - you can usually feel this with your fingers - give it a gentle pull and it should come away.
    Paul
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Yeah colo348
    I have mine off right now. You do have to take the screws out that you see, and as Jim mentioned pull towards you. However there is some double sided tape under the kickplate. Be careful pulling up. The kick plate is made out of thin sheet metal and bends. Like anything Ferrari makes it is way expensive to replace. I think for just one kickplate it is like $620. I have mine off completely because they were rusted and didn't want it to spread. That and there is no way I'm gonna spend over $600 each, for a piece of bent sheet metal.
  4. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    the proceedure Paul listed is exactly how I easily removed mine. It is an easy job- 5 minutes. I replaced mine witht he carbon fiber plates from KAZ automotive. They look great, and are less expensive then factory replacements. When I removed the factory ones, I didn't damage them, so if you need a set, you can have mine- CHEAP.
  5. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    348turbo, how much? If the price is right I just may buy them.
  6. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    ernie,
    I'll never use them again. Send me $100 + shipping and you can have the set. Keep in mind, I've removed the Ferrai rubber center pad and they are USED, not bent or damaged, but used, (ie scratches), but paintable.
    I'll be happy to send them. That being said, I'd advise a purchase of the carbon fiber ones from Andre at KAZ Automotive. They are beautiful!
  7. colo348
    colo348 Karting
    Nov 1, 2003
    143
    Colorado
    Jim
    Paul and Ernie,
    Thanks for the tips. I have a little rust on the drivers side (image I posted, not passenger side). I was going to use the carbon fiber kickplates from Valance to replace the rust prone factory part.
    Thanks again,
    Jim
  8. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    It's a deal! Drop me an e-mail so we can sort out the details. Also include your e-mail addy, cause for what ever reason when I try to just reply to the e-mail I get an undeliverable responce. Or better yet we can exchange phone numbers. I'll call you so it is on my dime.
  9. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,837
    East Yorkshire
    Justin Kenyon
    I have the carbon fiber ones on my car.... See the photos that I have posted on "348'S SHOW YOURSELVES" THREAD...
  10. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Removed mine, got the rubber insert out, took them somewhere locally and got them refinished, now they're good as new, cost total 20 ukp. Being so exposed to feet on entry not sure how long they will stay unscratched though
  11. 348 Turbo
    348 Turbo Formula 3
    Jul 17, 2002
    1,837
    Ernie,
    I can'r find an e-mail address for you. You can drop me an e-mail in my home account @ [email protected].
    Jeff
    I'll have them off pronto.
    Jeff
