348 major service - repair or replace? | Page 2 | FerrariChat
Discussion in '348/355' started by Dalema, Apr 3, 2019.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    The 348 water pump is particularly harder than the 308/328 and the 355.
  2. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    I remember reading somewhere about pressing the seal (or pressing something back together) and there is zero margin for error or it will leak.
    Ferraripilot likes this.
  3. yelcab
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    That is one thing that is common among all WP rebuilds. The 348 water pump is used as a idle bearing on the timing belt and has an inverted pulley which is not intuitive to remove. When it fails, the timing belt goes kaput and the engine coughs up a valve or two. On the 308/328/355, when it fails, you see a puddle on the floor, steam coming off the engine bay, and you normally have time to pull over and shut it off. Those water pumps can also be changed with the engine in the car. Not so for the 348, its engine has to come out for that. Due to the higher risks of collateral damage and the engine out requirement and the new water pump being only $400, it is better just to replace the water pump every 10 years (every other engine out service).
    Wade and AceMaster like this.
  4. Ricambi America
    Sponsor Owner
    Said one Ferrari designer to another, "hey, let's use the back of the timing belt to run the waterpump -- what could possibly go wrong?"
    Said another engineer sitting in a nearby cubicle, "If everything goes right, it's genius!"
    Said the marketing guy, "No worries gentlemen! We only have a two year warranty on these cars anyway!"
    Wade, baschul, Ryan... and 2 others like this.
  5. yelcab
    Nov 29, 2001
    13,674
    San Carlos, CA
    Mitchell Le
    Those are the same three guys who made the decision to drill through the oil pan twice to get to the gearbox? Yes, those three.
    steved033 and ernie like this.
  6. Dalema
    Dalema Rookie
    Jun 21, 2018
    32
    Bay Area
    Matt Dale
    Thanks. You are talking about part 170787? Is that the HE bearing in the above Ricambi listing. Looks like they replaced that in my last major.
  7. Dalema
    Dalema Rookie
    Jun 21, 2018
    32
    Bay Area
    Matt Dale
    Couple of questions:
    - When I look up the TSB10-34 kit on Ricambi it also lists part 144488 (driven gear). Is that required by the TSB?
    - Should the oil pump be replaced while there - wasn't sure on what to look for on that or how long they should go?
  8. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,367
    Atlanta, GA
    Steve D.
    on the 144488, most of us have the fences welded instead of buying a new one.
    sjd
    Ricambi America likes this.
  9. Ricambi America
    Sponsor Owner
    144488 is certainly not 'required' as long as you have the capacity to properly weld the fences in place.
  10. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Weld before buy, they are pressed on, even new ones. Tacked ones you wont have to worry about. Even if I bought new ones I would tack them. I tacked mine.
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    LOL. :)
  12. Ricambi America
    Sponsor Owner
  13. brent Lachelt
    brent Lachelt Formula 3
    Dec 6, 2003
    1,831
    Brownsburg, INDIANA
    Brent R.Lachelt
  14. Dalema
    Dalema Rookie
    Jun 21, 2018
    32
    Bay Area
    Matt Dale
    Thoughts on if oil has made its way into the clutch housing at some stage. Definite penetration of the clutch plates, however, no noticeable clutch slip when driving. Seal it up and drive it until it’s slips or just replace?
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Take the clutch apart and clean it with brake cleaner, replace the triple seals, and check the condition of the flywheel (making sure the seal hasn’t gone and flung grease everywhere).
