News
348 Mass Flow Sensors (MAF) - How expensive are to repair/replace??
Discussion in 'Technical Q&A' started by goyal99, Jul 30, 2004.
  1. goyal99
    goyal99 Karting
    Mar 5, 2002
    185
    Upstate NY - USA
    V K
    Okay, the MAF sensors are BOSCH part # 0 280 212 018 and should be relatively inexpensive to replace, I think.....
    Does anyone have a $$ figure on the sensor replacement??
    Can anyone recommend a place that specializes in BOSCH sensors for diagnostics and repair??
    Cheers - VK
  2. Noelrp
    Noelrp Formula Junior
    Aug 30, 2001
    630
    SSF
    Noel
    I would start at the dealer to set a baseline. Then call the 3rd party Ferrari vendors such as T. Rutlands or GT Car Parts to see if it is discounted.
    Although it is a Bosch item, I doubt that it's a generic/common MAF(most likely it is unique to 348).
    Good luck.
  3. ShanB
    ShanB Formula Junior
    Jul 9, 2003
    547
    Tejas/Europe/Desert
    shanb
    Hi. It's available from Rockauto.com listed for $329. Also this same part # was used on certain SAABs (900/9000) of the same vintage. The SAAB part (same part #) can be had as low as $200 rebuilt if that helps.
    Shan
  4. goyal99
    goyal99 Karting
    Mar 5, 2002
    185
    Upstate NY - USA
    V K
    Thanks for the tip...
    I think the SAAB numbers (I found online) are close but not the same... ie the last 3 digits end in 017 or 016 (the 348 ends in xxx 018)
    Are you sure the SAAB MAF is the same part #?? If so, what year that would be and which model SAAB (Turbo or non)??
    It's worth a shot if the MAFs are the same part number.....I have a SAAB repair center close by and I will check to verify.
    Regards - VK
  5. dapper
    dapper Formula Junior
    Nov 10, 2003
    710
    Bristol, UK
    Dave
    Just had my 348 annual MOT test, the first thing the garage owner said when I opened the engine bay lid was, "hey, do you know those are exactly the same as used on a Volvo" as he pointed to the MAF sensor assemblies.
    Now I believe his experience is mainly of 328 F cars (he carries out the MOT on one of my neighbours cars every year), so it may be that he was thinking the 348 are the same, but it may well be worth checking, especially as the Saab, another Swedish vehicle, is being referred to here.
  6. goyal99
    goyal99 Karting
    Mar 5, 2002
    185
    Upstate NY - USA
    V K
    For anyone else you might be reading this thread about the MAF sensors been similar as in the Volvo or Saab cars, I can tell you they ARE NOT the same....Similar looking maybe, but not the same....
    I know because I already have a couple Saab MAF units (from eBay), which look very similar on the outside but the wiring is different and also the BOSCH number on the housing is different....The last 3 digits should be 018 for a 348.....Most late model BOSCH MAF units use the 3-hot-wire air flow sensors.
    However, if anyone has successfully mated a Saab/Volvo MAF unit on a F-car and made it work correctly, we'd like to hear about it...It can probably be done but at $300 for a brand new MAF unit, I feel it's not worth the trouble...
    VK
  7. dasadrew
    dasadrew Formula Junior
    Aug 1, 2004
    683
    Germany
    Drew H.
    The Bosch online spares database lists the above number as only applicable to 348 (and Mondial T). List price from Bosch in Germany is €408!
