348 Odd Overheating Problem | Page 2 | FerrariChat
Discussion in '348/355' started by Koenig1, Aug 11, 2018.
  1. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    OK, here's my update.... and it's a good one!!! Refilled with 50/50, bleed the lower hose(heater) with key on, then started car. Once the fans started running, bled the upper hose, made sure all air was out. temps move between 87C and 92C all day long. Traffic, downtown stop lights, nothing, absolutely nothing above 92C. Fans cycled on/off, cooling quickly.... just shake my head!!! Highway rolling is about 87/88C, cooler than it's ever been! So very PLEASED/relieved!!!
    I can't really point to one thing being the problem. Obviously, the passenger side fan connection was 1, although the fan side started/stopped, but probably turning at 1/2 it's speed. Both rads being cleaned out( tech said they weren't dirty/clogged) has taken the running (highway)temps lower than its ever been...! I tried getting it hot, gave the engine a good workout, temps just stayed COOL, UNBELIEVABLE!!!
    I thank all of you for your inputs, and suggestions, to stop me from pulling this engine. I must say that I had little faith this am, as there did not seem to be a real cause. Tim... I did do a thermal read, top & bottom of each rad. In my exuberance, I did not write the #'s down, but the average #s were about 3>5*(F) bottom to top. So to anyone with a heat related headache, do your due diligence before choosing to Pull It!
    thanks again....
  2. GTO Joe
    GTO Joe Formula 3
    1,002
    Charlotte, NC
    Joseph Troutwine
    All's well that ends well, glad it worked out for you.
  3. Therapon
    Therapon Rookie
    Jul 23, 2022
    2
    Limassol
    Therapon Mylonas
    I have exact the same problem as you had. I will start with checking the Radiators Fans if are working properly
  4. David Baldwin
    David Baldwin Rookie
    May 5, 2019
    15
    Kent, United Kingdom
    David Baldwin
    Hi very interesting threads on Ferrari 348 running hot! I am over in the UK I had a 308 GTBi for a couple of years and earlier this year I picked up a 32,000 mile 348ts Which is a lovely car but over the last few weeks it started to get a bit hot, After taking the R/H rear arch liner out i noticed a small leak along the top of the radiator, I removed the radiator and took it to a local radiator repair shop who did a repair then leak tested and pressure tested it all for £50. My next step was to fit new water temp and oil temp sensors on the radiator, Then fit two new coolant temp sensors and the temp gauge temp sensor which is in between both coolant temp sensors, I fitted a new thermostat then refilled the system with both bleed screws open until I got coolant coming out, I had also noticed an E5 error code on my heater display so I stripped out the luggage bay around the bulkhead and removed the Bosch motor and heater valve, these I took into work and gave to one of our bench electronics engineers and he took the Bosch unit apart cleaned it and tested it and is all ok he said I found the heater valve a little stiff this was lubed and now works freely, I refitted this today and I am glad to say it opened and let the coolant through so I fired the car up with the heaters now working and no E5 code it did not take long to bleed the system, A quick test drive and the car was faultless the needle pointed just below the middle mark and when I left the car stationary just on tick over the fans were cutting in and out which was a joy to hear so I now have a 348 that does not overheat, Thanks to this great forum and tips it was quite an enjoyable task which would have cost a small fortune at a main agents.
    Qavion likes this.
  5. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    Sorry I haven't read all of the replies but I thought I would chime in I had a similar problem with my reply older 328. 1st of all I recommend you go to Harbor freight and get an inexpensive infrared thermometer that way you can check each radiator each cylinder head water jacket and even the coolant tank for correct accurate temperatures you can't always trust that your gauge on your - is not off. And finally what I wound up doing is I took the thermostat and removed the "disk" or gits which gives it some restriction but allows the water to flow freely in other words making the thermostat think that it's open all the time I know this isn't the greatest but it solved my problem.
  6. ClydeM
    ClydeM F1 World Champ
    12,208
    Wayne, NJ
    Clyde E. McMurdy
