348 performance chip | FerrariChat
Discussion in '348/355' started by DonJuan348, Sep 16, 2009.
  1. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    Has anyone installed a performance chip on their 348 ? If so which one and what performance benefits did you feel ?
  2. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    To the best of my (limited) memory, I don't think anyone in this section has ACTUAL dyno runs before and after installing a chip. The general consensus seems to be - save your money - as the actual performance gains are highly over-stated by the manufacturers. I do recall one manufacturer in Italy that was supposed to be quite good and were the only ones that had "cracked" the code of the Motronic 5.2 ECU (obviously not applicable to your 348).
    I'm sure others will chime in here.
  3. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    After the chip, the car can stay with a VW GTI.
    Gotcha!
  4. Tom_C
    Tom_C Karting
    Feb 20, 2008
    233
    Raleigh area, NC
    Tom C
    #4 Tom_C, Sep 16, 2009
    I have a set of "supposed" performance chips that came with the car when I bought it from a fellow Fchatter. I hope to do a baseline dyno sometime in the near future, and then switch in the performance chips and run again. I honestly don't remember why the performance chips weren't put in the car when I got it.... No timeframe for the above, but I am interested, and will post the results when I get them. :)
  5. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Dino (Ingegnere) - hope I spelled his id correct - has put in a chip in his 348 SS - I believe his company makes the chip. You can check with him for price / hp/torque improvements
  6. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,440
    On the Limit
    Dino
    We have been doing 348 software work for quite some time. The programming, along with a Tubi yields ~10-12% increases in hp/tq.
    What is really apparent is the improved throttle response, and vastly improved mid range. It really improves the package. My car is also ~200 lbs lighter. Between the extra power and the lighter weight, the I have no problems running down 355s. 360s are a little tougher, but well within the reach of my 348. If that gives you an idea of the package.
    albert328gts likes this.
  7. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,700
    Not questioning you data, but I routinely run down 360 F1s on r-compound tires with my 95 F355 on street tires (S03s) with M6 tranny.
  8. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,321
    Palos Verdes
    Vince V
    #9 vvassallo, Sep 16, 2009
    I got ND Pink Chips@ which are less aggressive than his Red Chips@ combined with all my other mods. Not sure what the chips themselves will do. It's actually more of a package of mods that yield results, not just a simple EPROM replacement.
  9. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,440
    On the Limit
    Dino
    Some of what you are inferring is in the driver I assume.
    While being a chief FCA instructor, obviously there is a fair amount of involvement in skill levels in the corners, but I am talking about straight line performance.
    I am sure that you are a superb driver, and I don't want to get in a debate with you. I was trying to answer a question about relative performance of the 348 that has been ECU tuned.
  10. BrandSB
    BrandSB Karting
    Jun 11, 2008
    236
    Canton, Michigan
    Steve
  11. speedy_sam
    Jul 13, 2004
    5,559
    TX
    Sameer
    if I am not mistaken Veloce Performance linked above is a company owned by Dino (Ingenere)
  12. Luc
    Luc Karting
    Mar 22, 2009
    50
    If one of you dared sending me an ECU, I could work on it with one of my good friends who has a passion for Italians (owns several Maserati's) and is an excellent engineer. He already reverse engineered the ML in my Porsche, the ones used in Alfa 164, His Maz... if he's OK for doing this I could write the application for modifying the timings.
    The thing is to get an ECU for at least 2 or 3 months.
  13. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Dino:
    Only $1450.00 for the chip! That's fantastic. Does this include the Motronic 5.2 ECU or only the 2.7?
  14. Luc
    Luc Karting
    Mar 22, 2009
    50
    Maybe you're a good driver too ;)
  15. DonJuan348
    Aug 5, 2008
    4,442
    Taxing Jersey
    F chat member should get a discount..
  16. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,440
    On the Limit
    Dino
    Yes... both 2.7 and 5.2
    Some say.... :)
    I am sure that we can work something out.
  17. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    I have a 1993 348TB SS. I bought the car 8 years ago. The previous owner had T.P.S chips for the car. I then had the timing changed to the Challenge specs, installed the T.P.S. chips, and removed the cats. The car runs stronger (by the seat of my pants), but I will have it dynoed to get a reading. Hope to post that number soon.
  18. F355Bob
    F355Bob Formula 3
    What are the challange timing changes? Do you have the timing numbers?
  19. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    I don't have them. But, I've seen them here on Ferrarichat. Do a search, you'll find them. Or start a new post, someone will post them quickly I'm sure.
  20. Samy
    Samy Formula Junior
    Dec 2, 2005
    603
    I chiptuned 348 with 2.5 and 2.7 Ecus and dynod them. You can only get safe benefits without mechanical modifications when you run on better fuel then 95 ROZ. Then you can get hp gain from earlier ignition angles. Here in germany we have 98 ROZ and 100 ROZ on the gas stations so depending on wich fuel i adjust the mappings the benefit will be higher or lower. Without changing the fuel or changing the cams i wouldn't raise the ignition angle much and the hp benefits would be near zero. F.e. 98 ROZ rest of the engine stock i got 15 hp max on 7150rpm wich was then 335hp. Bigger benefits are possible with changed inlet manifolds with individual throttle valves and changed cams.
